Page 14 of 28 FirstFirst ... 4121314151624 ... LastLast
Results 131 to 140 of 271
  1. #131
    Senior Member Jamesconn's Avatar
    Jun 2011
    Donegal
    OK, Tempted 2 tickets just bought through PayPal
  2. #132
    Pro Driver
    Little update......
    So this is the first time ive sat down with a 20v in front of me and thought about the water pipe re-locate problem
    There is a few different designs out there for re-location kits and i wanted to see if the original parts could be modified without buying a kit, so here is what i came up with
    I fitted the engine and realised that it fits in the 86 with the heater and sensor block attached to the head if you remove the thermostat
    So......
    I wholesaw'd a piece of alu to make a blank for where the thermostat was and welded it up. Heater pipes were the next problem, one will work but has to be shortened to get a 90degree hose on it and clear the bulkhead. The other wont work so i welded it up
    So i needed a return for the heater matrix so i used the original top rad hose position and welded a smaller tube into the original bolt on alu piece. Got some xtraflex samco hose to make a new heater hose
    For the new top rad hose i used the original bullhorn head to water pump piece, cut it and turned it so that it now faces forward. I also welded in the rad fan sensor bung from the original thermostat housing bottom rad hose flange and this will switch the electric fan now as we have retained the 20v water pump system and havent needed to covert to ae86 water pump which i think is silly
    So this is how the heater assembly now looks
    This is how the bullhorn piece looks fitted and it clears the original 20v alternator in its original position. Now all thats left is fit a new top rad hose and a new bottom rad hose from the rear of the water pump with a couple of 90degree bends and an inline competition thermostat which will be drilled for water bypass during engine warm up
  3. #133
    Member
    Aug 2011
    You'll b well busy to have it ready for "a great Christmas present for some one" Im sure someone would be glad to finish it off for ya.
  4. #134
    Driftfest
    Oct 2011
    CORK
    Quote Originally Posted by D McNamara View Post
    Little update......
    So......
    Whats with the red nut on the block and the blue rinse on the manifold ha ha
  5. #135
    Pro Driver
    Quote Originally Posted by 2cam86 View Post
    you offering??
    painter is up the walls so waiting on him
  6. #136
    Pro Driver
    Quote Originally Posted by hillclimber 70s View Post
    haha red nut is off the inside of the door it was just to hand, blue rinse is ceramic coating or was one time
  7. #137
    Site Trader : Barrys Motorsport
    what wheels r u putting on it?
  8. #138
    Pro Driver
    Quote Originally Posted by mbarry View Post
    havent fully decided yet
  9. #139
    Member
    Aug 2011
    Wolfrace katanas laad!!
  10. #140
    Pro Driver
    Looking for some feedback here....
    Car will be painted white with black bumpers so for wheels would you choose.....
    Silver, White, Gold, Grey, Gloss black or Satin black??
    Lets not get into brands and models of wheels just asking about colour opinions on a white car with black bumpers
