i wont one,i wont one, i wont one, i wont wonta nice set of rotas, 18"x9", also you should think about ploybush the hole underside. my bro's R33 is polybush, and it makes such a big difference, it completey changes the car.
Very clean looking skyline!!!
where did you get the roof spoiler dude???
looks savage on the wheels man but needs lower and more front camber to look perfect! dont bother with front camber arms for them, just get a set of s14 lower arms, will pull her out abit nice!![]()
cheers lad must just sort out sub frame next have 13 subframe to go on to eleminate hicas cos it failed nct on it
once she goes trough the test plan is to lower more wit camber in front will top mounts work or will i need to go for s14 lca???
how did u do the the lines for the steering when u did ur did u judt loop them or what did u do??
@kenny i got spoiler with the car but u can get them off origan or think rhd japan sell then to
no man they use a double wishbone type front setup, so top camber mounts dont work, u need to buy top camber arms! but i had some didnt find them great, put back in std, and got s14 lower arms was way better, cos it pushes out the bottom more so then pull in the top! i looped them at the very front man ! removed all solenoids an stuff! had to get a piece of rubber pipe, about 1 foot long, and cut one of the pipes, and loop it ! il find a pic for ya later!
ah yes i forgot bout that so used to working on s bodys so bacasicaly il have to get s14 lower arms and change ball joints cos s14 are different ant they?
oh shit ya i didnt think of rubber pipe i was goin getn copper pipe and having w flare it good idea ted if u can find that pib it b the job cheers lad
havent done much latly sorted out my lighting problem turned out to be connection at back of light swich was compleatly melted
also fitted 8mm spacers all round sitting nicaly now although need arches roled badly rubing lik a bitch
just waiting on 33lca in the post thanks rory(silvertooth) then before people jump on the banwagen it will b going lower
plan on fitting subframe to during the week so that should get me trough nct and il see how low a can go real itch to drop it now but il just have to rase it for nct so il just wait
few random shots also took out grill
