Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
    Default Project Zedspeed. VQ powered MK1 Escort
    Right first I am going to say that this isn't strictly a drift car. It may possibly see more track driving or even drag racing but I thought you guys would appreciate the project anyway. We would like to use it for a some more drifting but due to the way its being built I don't think it will be eligible for many comps but I am sure we will be able to have some fun with it!
    So it pretty much starts here:
    An extremly clean MK1 Escort shell with the front end panels removed, the wings have just been fitted quickly as a mock up.
    and this is what will be powering it:
    A 350Z VQ35 engine that has had a few light mods and a remap to produce 311bhp. The VQ was chosen as it is quite a large capacity engine for its relatively light weight. There is also many tuning options avaliable to up the power in the future and it is coupled to a pretty robust driveline.
    So obviously this wouldn't be the easiest fit in an original MK1 escort shell so we have decided to build the car as a full spaceframe chassis. This should allow us to keep the weight as low as possible, it has also allowed us to choose our suspension and running gear freely.
    With this in mind we first decided to run an independant rear suspension set-up. We considered a few choices but wanted a readily avaliable, reasonably priced option. so...
    Yep your pretty much straight forward S14 rear subframe. This was an obvious choice as there are plenty about, they can be made pretty much fully adjustable at a low cost and with the addtion of GTR parts can be made to handle large amounts of power.
    Again at the front an S14 front set up was chosen for pretty much the same reason as the rear. Got hold of this lot to mock up the front:
    As you may have seen in the first pic the car already has the rear arches just mocked on the rear. You may have thought that they look a bit larger than the regular 'bubble' arches fitted to MK1 escorts. This is because a complete Zakspeed kit has been purchased (hence the project name!) to run on the car which will allow us to run some mega sized tyres for high levels of grip.
    So the next job is to consult with the frame builder and take numerous measurments to see how we will want to mount the running gear and suspension in the frame and then get cracking with constructing the frame as at the moment it is just a load of pipes!
    Will update as we go along!
    looks good ,a far bit of work ahead .
    Team ManFoot Famous jh's Avatar
    Dungarvan, Co. Waterford
    Awesome.
    One thing, STOP TAKING PICS WITH THAT STUPID IPHONE AN USE A PROPER CAMERA...
    We need proper pics of this
    Some say wide wheels and skinny women fear him. Some say vice versa.
    Team Manfoot
    Quote Originally Posted by Famous jh View Post
    Awesome.
    Ya I know! I can't afford a decent camera but I will see if I can find something laying around!
    di Member richy's Avatar
    Wow, this is gonna be class! Good luck with the build
    Team Beard
    Dec 2010
    o ye dump the camra, but good luck with the buld its going to be some car,,
    Loaded up and off to have the spaceframe made.
    Better camera
    Few pics of the progress the frame builder is making.
    Should have more pics soon!
    What kind of final weight are ye looking at Billy?
    400 horses............. 1 jockey
    Cork, Ireland
    Wow...........serious machine lad, now i can stop wondering where the rack is going, i knew ur old lad wasnt much of a nissan man
    TEAM MANFOOT
