Quote Originally Posted by Bkiely View Post
is there a big difference in the sr20? and would the ca18 be a strong engine ?
thinking of getting a uk 200sx on friday would go for a jap but lack of money .. any info on this car would be appreciated as i having a clue about them thanks
The CA18DET has a terrible reputation for running bearings.
This is mainly due to the fact that they were originally sold as a STD type car in the UK.
Then they were not serviced often enough with the right oil grade.
As a result once they were used hard they would blow up.
If you get one form the UK and the oil is not like coal. I would recommend a set of bearings an Oil pump rebuild and it should be as good as an SR in the bottom end. They have better designed heads with nothing to break like the SR rocker problem. They respond really well to tuning and getting one to 350bhp is as easy as it is with an SR.
Also the UK and Irish cars just rusted away from the sills and nearly everywhere else too.
There are plenty of cheap SR engined Jap imports in Ireland going chap at the moment.
Robbie
