I had a rough lap in my r32 in mondello and when i came in was spluttering and them wouldn't start, turns out I frayed the loom on full lock and it was messing with fuelling and spark and all! Maybe worth checking?
Sig removed - See rules
Its not the tps for me and the wiring under the arch is fine too. @Sil80drifter, did you figure yours out yet?
this happened to mine ,just after coming off the rollers ,spin up the road then left up ,tryed all the mentioned above and in the end it was the ecu not getting full voltage,pulled a wire from the ignition to the ecu power supply and away she went ,
3 fprs, 2 fuel pumps, a full day of pricking about and an afm later and it turned out to be the afm and not the fpr that we originally thought! Anybody got a rb20 afm?
