Results 1 to 10 of 17
Thread: front camber
    Default front camber
    wat ideally is the amount of front camber to use for drifting i fitted the modified hubs etcarms etc today and refitted the coilovers and to use the wheels i want to i needed to run about 5 to 6 degrees camber would this be ok or to much
    ideally wanting to here from people that have experience of having this much camber and knowing wat the car drove like on track felt like etc
    yes thats too much. 3.5 to 4 is ideal
    Thread Rapist!!! Diesel-Dick's Avatar
    Aug 2010
    Dungarvan, Co. Waterford
    just roll or flare your arches so ur wheels will fit with bout 3 degrees?
    Lad its pointless putting up a thread like this because each it to there own....! Some like 3 degrees others like 6.....!
    Just a matter of playing around with it and seeing which works best 4 you...!
    x2 bring it down on sunday for the m1 and we can try set it up
    then out for a hour see how it goes, change it again out for another hour
    di Member S13..KEV's Avatar
    lad up to you at the end of the day.most use 3 to 4 as chris said but i have heard lads in pro drift use 8.5 all comes down to driver.i use about 3.5 and really like it.robbie is spot on.each to there own
    Aug 2010
    What is the benefits of having less or more camber on the front? How does it affect steering response, feedback, lock etc?
    http://tyresdublin.ie/
    may see wat works first then
    Quote Originally Posted by S14a johno View Post
    it,ll be set up before the m1
    Quote Originally Posted by S13..KEV View Post
    cool ill call up to u over the weekend and chat wit u yours is near enough the same sut up as mine
    Quote Originally Posted by Diesel-Dick View Post
    ive wide arches on already and stretched tyres
    Team ManFoot Famous jh's Avatar
    Quote Originally Posted by podge View Post
    Goin by the pics in your build thread you could afford to goin down at LEAST one more tyre size lad!
    As for the wings, cut the fuckers if you have too! Set up should never be determined by fitment! Dont get that at all myself....An as for how much camber to run, i doubt 99% of people would notice a difference in settings..
    Some say wide wheels and skinny women fear him. Some say vice versa.
    Team Manfoot
