i presume the front end isnt finished??...theres no cross member in the front with the way the engine mounts are built!!.... hows the suspension and wishbones work, strength etc?
Signature removed
Look very carefully at the photos you will see just how strong the mounts and chassis are. There will be a cross member and some trick drift steering setup allowing for the car to have no ackerman and massive lock. It will not have the normal tension rods but will use compression struts.
Robbie
can this still be called an s15
serious work gone into that and your only started on it cant wait to see the end result
f**k me there is some serious work going in there,
some tasty work being done,
this is nothing short of epic
jesus fuking christ!!!!!!!!............. what a machine.
It's a different world when your going into the kinda detail to chassis strength that is going into this build,,, you'd be fairly drunk by the end,,, ha ha
The floor is only light steel and the front and rear chassis legs are still totally intact, so by replacing the floor with light steel and some bracing to make it stronger and safer,, I don't see why it should be a problem since putting a new tunnel in a car would fall under the same modification,,
