Page 9 of 25 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 245
  1. #81
    Theres nothin like a late 1, few more small updates. Got subframe fully sorted, worked out class in the end I think
    you's might see a little better on this 1 that the collars are not centre
    will not get a solider sub-frame than that
    start pullin out the arms at the front end (the rear is ready to rock)
    Just a matter of waiting on the postman now with the delivery
  2. #82
    Just a small update on suspension and stability:
    1.Existing stuff (that I can think of)
    Tein superdrift coilovers
    Cusco struts front & rear
    Cusco rear camber(do not know if they will work with new set-up)
    Pillow ball joint drop links (dont think it's great photo)
    2. New stuff
    Driftworks rear toe
    Driftworks front camber
    Driftworks front tension
    Driftworks rear adjustable lower arms(replaces wishbones)
    This is a defo big eventually, not before time!!!!
    Driftworks hydro hanbrakes & braided lines
    They did not have full stock, so Driftworks rear traction and the front lower arms will follow soon when they have them back in.
    Massive thanks to Wezzzzzzz at WKD
  3. #83
    Just few wee updates on fitting suspension: Front camber arms fitted
    Few pics on how rear end is starting to turn out,fairly happy so far
    New rear wheel bearings
    Any comments or tips welcome for were I am going wrong? cheers
  4. #84
    di Member SR20Eric's Avatar
    Co. Meath
    Brother, this is one of the best builds ive seen on here in a long time!
    keep up the good work, ur playin a stormer
    u ever need a hand, u know were i am
  5. #85
    Quote Originally Posted by SR20Eric View Post
    Jaysus man thanks a mill for the really nice, sound comment
    But myself I would'nt go that far, some of the other yokes are jus chronic!!
    Thanks for the offer of spare hands too, but getting there on me own, Eric I'm a stubborn c.nt seems ta pay off haha. got an odd dig out here & there...Daragh Swan does as the welding etc..he's the man, Professional!! If I ever get stuck stuck, I'l be pm'n you ..thanks again mate nice to get them kind of comments
  6. #86
    Right lads and lassies, small update but this is more to help other people out, any of the nissan heads out there! Today I found out an advantage when it comes to the suspension end of things, some people might know this but its got to do with tension rods
    Notice the off-set on these, well there GTR tension rods, this was a simple mistake in the order that has benifited me. As in the tension rods are further out of the way for when you start advancing lock! To make them fit, the collars jus have be skimmed down couple of mm on the ball joint end so they fit.
    Was just bout post them back, until Kev rang me, cheers man
  7. #87
    Another small update, another small delivery
    Driftworks front lower arms
    Driftworks rear traction arms
    This is what I was on about the tension rods above, its the ball joint end you need to take a wee bit of the collars if you get the GTR tension rods with the off-set
    Would'nt think anything is done but thats Darragh again, everything is left professional! Ready to pop into car
    Got the ball joint bushes pressed out on the rear hubs, where the Hi-cas use to be, ready for toe arms
    Thats it for the min
  8. #88
    di Member Stevie e39 drift's Avatar
    shercock cavan
    seen it now niall , i wasnt on earlier serious money time n parts goin inta this epic car as it was wats it gona be like wen done :O
  9. #89
    Quote Originally Posted by Stevie e39 drift View Post
    Thanks Stevie boi, always good for the sound, bang on comments. Well trying to increase stability as much as poss so hopefully it will handle a bit better bro. You'v got that right bout the effort & time, but I will not stop, at end of day I'm doin it for Brian, not for myself simple as. If it was for me I'd have giving up long time ago!
    Keep the faith
  10. #90
    Had wee problem with the roof spoiler but this will show how safe e-bay generally is. Its as if the courier stood at back door and fired it in van!! I was delivered this!
    Got on the phone straight away, at end of day it was brand new and damaged so the lads were very helpful and sound about it, so today I got suprise in post
    Happy out, cheers to Rob in Madmotors, now I have 2roof spoilers and all the damaged 1 needs is bit of fillers. Could butt the 2 together and have a super roof spoiler
    Ah no but e-bay is safe out cause heard on many ocasions oh I would'nt buy on the net
