Hi fellows. windows dont wont in the skyline and are stuck closed.
What sort of perspex is needed for the likes of perspex, is there any requirements?
also where and how much is it?
thank you please!!
thank you please!!
poly carbonate is nearly bullet proof but heavier as far as I know
Perspex and polycarbonate are similar in weight polycarbonate is shatter proof where Perspex isnt man factor is polycarb is expensive,get onto frankie he got a full set for his 2.2 180sx if my mind serves me right hope this helps
cool thanks lads. so would perspex still be ok? say 3mm?
3mm would be grand but be careful drilling it fragile as fuck,and cut as much as you can with a skilsaw,jigsaw with new blade for the corners![]()
i need to ask why you spending money on the car
One more thing blow torch the edges when ya have it cut to size leaves a glass finish nobody will know any different
id say 10mins wireing would sort it pewee the windows did work perfect in that car before gus got at it
because he cut the frames out of the doors theres feck all support for the weight of them so theyre starting to fall out of place now!
