Results 1 to 10 of 245
    Just few wee updates on fitting suspension: Front camber arms fitted
    Few pics on how rear end is starting to turn out,fairly happy so far
    New rear wheel bearings
    Any comments or tips welcome for were I am going wrong? cheers
    di Member SR20Eric's Avatar
    Co. Meath
    Brother, this is one of the best builds ive seen on here in a long time!
    keep up the good work, ur playin a stormer
    u ever need a hand, u know were i am
    Quote Originally Posted by SR20Eric View Post
    Jaysus man thanks a mill for the really nice, sound comment
    But myself I would'nt go that far, some of the other yokes are jus chronic!!
    Thanks for the offer of spare hands too, but getting there on me own, Eric I'm a stubborn c.nt seems ta pay off haha. got an odd dig out here & there...Daragh Swan does as the welding etc..he's the man, Professional!! If I ever get stuck stuck, I'l be pm'n you ..thanks again mate nice to get them kind of comments
    Right lads and lassies, small update but this is more to help other people out, any of the nissan heads out there! Today I found out an advantage when it comes to the suspension end of things, some people might know this but its got to do with tension rods
    Notice the off-set on these, well there GTR tension rods, this was a simple mistake in the order that has benifited me. As in the tension rods are further out of the way for when you start advancing lock! To make them fit, the collars jus have be skimmed down couple of mm on the ball joint end so they fit.
    Was just bout post them back, until Kev rang me, cheers man
    Another small update, another small delivery
    Driftworks front lower arms
    Driftworks rear traction arms
    This is what I was on about the tension rods above, its the ball joint end you need to take a wee bit of the collars if you get the GTR tension rods with the off-set
    Would'nt think anything is done but thats Darragh again, everything is left professional! Ready to pop into car
    Got the ball joint bushes pressed out on the rear hubs, where the Hi-cas use to be, ready for toe arms
    Thats it for the min
    di Member Stevie e39 drift's Avatar
    shercock cavan
    seen it now niall , i wasnt on earlier serious money time n parts goin inta this epic car as it was wats it gona be like wen done :O
    Quote Originally Posted by Stevie e39 drift View Post
    Thanks Stevie boi, always good for the sound, bang on comments. Well trying to increase stability as much as poss so hopefully it will handle a bit better bro. You'v got that right bout the effort & time, but I will not stop, at end of day I'm doin it for Brian, not for myself simple as. If it was for me I'd have giving up long time ago!
    Keep the faith
