Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    did you plug a computer in to check the fault? so can find the area where problem is ?
  2. #12
    di Member Sideways Simon....'s Avatar
    Mayo
    Quote Originally Posted by Eoin k View Post
    cheers Simon. Sounds complicated. where do I start or who does it??
    Its easy do Eoin,
    http://www.sxoc.com/vbb/showthread.p...34#post5211034
  3. #13
    Senior Member Eoin k's Avatar
    I plugged it in awhile back and no faults showing after the new squib. Its just a standard ecu and I presume standard injectors. Is the airbag loom just like a loop that I can put the resistor in anywhere or is there several wires?? thanks for the replies everyone.
  4. #14
    Mayo
    Quote Originally Posted by Sideways Simon.... View Post
  5. #15
    Ok-i went to maplin and got 2.7 resistor. Tried on the drivers side first and then passenger side. No joy-light still on constant. Any other ideas to try??
