Well lad...
If your going repairing those dents u'l need to sand down the damaged area and just around it with p80 grit sandpaper.
Then apply the filler evenly, Mixing filler is basically a golf ball of filler to a pea of hardener.
Sand this with 80 grit and repeat the filler process until u'v a desired finish.
Before primer rub it down again with p180 and then p240 as this will remove any deep scratches.
Rub down around the filler area aswell with p240.
Mask around the primed areas but not too close to the filler as priming onto the masking tape will leave an edge which is a cunt to rub down after.
Once filler has dried get a bucket of water and p800 wet and dry sandpaper and start rubbin the filler until its smooth, U shuldnt be able to feel where the primer ends and old paint starts, If u have a sanding block use it as itl remove remove waves if used right.
Uv a few options then for rubbing down the rest of the car id just get a tub of blend prep and a good lenght of Grey scotch pad and again ur bucket of water... And just basically rub the shit outta the whole car until all shiny surfaces are matt.
Remove bumpers and skirts etc.
Mask up what u need to mask on the car and paint on.
For paint id recommend going clear over base.
Basically get your colour base (gloss black) ans ul need to put on prob 3- 4 coats.... Leaving time between each coat to dry fully.
Get a regulator for the end of ur gun and ul b sprayin at a tad over 2 bar pressure.
Next ul need about 3 coats of laquor, raise ur pressure a tad and read the instructions on ur laquor tin ( most have different methods for painting)
Id recommend Max Meyer where ud apply 2 40 per cent coats leavin about 10 mins between coats and then an 80 per cent coat to get ur desired finish.
I could go on and on but im boring myself any more particular questions just ask and il try help.
Every panel basher has different methods and these are just mine.
