Results 1 to 10 of 20
    Default Hks gtss vs S15 turbo
    So has anyone got experience of both of these turbos?
    Im undecided on which one to get.
    Is the gtss worth the extra few hundred quid?
    How do they compare as regards spool and top end?
    Quote Originally Posted by sideways boy View Post
    ive the s15 one and its great, plenty of power for what i use the car for, very quick spool with power pretty much all the way through the rev band. max power is circa 320 bhp iirc??
    anyone wanna swap s15 helical lsd for 1.5 or 2 way...
    Pro Driver
    If you can go the extra few quid, the gtss is a better turbo
    Ya Money wouldnt be an issue Darren. Does it have a better top end than the S15?
    Pro Driver
    well if money aint an issue get a gtrs and a set of 550 injectors and make some real ponies
    gtss will flow to about 360hp
    u will need a re-map anyway to get the most from a gtss too
    do you have an aftermarket ecu?
    May 2010
    hav had 3 gt-ss turbos on my car, great turbo. great spool. i was making 355bhp with 555cc's z32, poncams, etc.......... the last one i used was onn a gtr twin turbo setup, smaller exhaust, better spool, bit less power but had more torque
    the oil restrictor in the oil feed got blocked in my last one, killed the turbo. then i ran an s15 turbo. nice little turbo. but no comparison to the gtss...
    however..... they are a fragile turbo in my opinion(espically the bearings) , if i was buying again id go for the garrett equivlant. or maybe the slightly larger gt2871r. hope this helps.
    Pro Driver
    Quote Originally Posted by bubble1984 View Post
    I ran one for 4 years on a drift car so i dont think they are that fragile
    Also they are made by garrett for HKS with a larger exhaust turbine etc compared to a normal t28
    one model gt2871r is the same as gtrs. There are a good few gt2871r models with a lot of differences
    Quote Originally Posted by D McNamara View Post
    nice info their on the gt2871 darren, is their any perticular model better than the other or wat is the difference
    Pro Driver
    Quote Originally Posted by ian g sr20 View Post
    pretty sure this is the one to go for http://www.turbobygarrett.com/turbob..._472560_15.htm
    i put a lot of reasearch into it when i was buying one but have kind of forgot half of it now
    Pro Driver
    Rule of thumb would be smaller exhaust turbine A/R is more responsive, larger A/R more peak power at higher rpm
