Results 1 to 9 of 9
    Dublin
    Default Defi Gauge Install.. Oil Temp / Water Temp
    Quick question lads.
    First time at this lads so hopefully not a too tick question! Where should I pulling the water temperature from? I thinking about removing the water temp sensor completely and plugging the defi sender into it? Its just off the inlet side of the block. I know theres another one beside it.. this looks like the water sensor running to the ECU (Silly to remove this). I could also get an adaptor for the hose running from the rad back into the block (requires ordering the adaptop)... but I was thinking of putting a fan controller here.. like this http://www.apexperformance.co.uk/cat...478f42ec8e01d4
    For the oil temperature, it appears theres a block off on the exhaust side close to wear the turbo oil/ water feed the turbo on the block. Is this blocked off screw water or oil, and is this where everyone has oil temp read from?
    So two questions:
    Where are people pulling water temp?
    Where are people pulling oil temp?
    oh ye its a 180
    Cheers,
    Si
    Sorry ment telling you the other night that you will need an oil sandwhich plate for oil temp and one of them lads for the hose for your water temp.
    Dublin
    Quote Originally Posted by Newsome View Post
    I'm gna take the water temp from the were the standard one is on the block. Just need to get a reducer for that. And for the oil temp.. gna tea off the sensor beside the filter.. should be pressure there.
    Heres the two things you need, get the sandwitch plate as then ya can run both oil temp and pressure yano,
    If your getting rid of the standard water temp yar water temp on the dash will prob stop operating....
    Think these are the cheapest ones to get,
    http://cgi.ebay.co.uk/SANDWICH-PLATE...48121769056447
    http://cgi.ebay.co.uk/36mm-WATER-PIP...61169880243964
    Dublin
    Quote Originally Posted by P.s13 silvy View Post
    Sound man. I'll pick these up so, will save alot of hassle
    Dublin
    rang a few places looking for a sandwich plate, no joy.. neone know wer i could source one in dublin. I'm unsure of the fitment sizes on the ebay link posted
    id ask bart to see if he could get u one
    When gettin a sandwich plate I wouldn't cheap out on it as you don't want oil leaks all over the place, I got mine of driftworks for 80 quid and does the job perfect!
    Sig removed - See rules
    Dublin
    Fairplay to NewSome for sorting me out. Got a nice sandwich plate and rad hose adaptor.. i'll should be seeing the gauges light up shortly!
    Sound lads and Happy New Year
