Quick question lads.
First time at this lads so hopefully not a too tick question! Where should I pulling the water temperature from? I thinking about removing the water temp sensor completely and plugging the defi sender into it? Its just off the inlet side of the block. I know theres another one beside it.. this looks like the water sensor running to the ECU (Silly to remove this). I could also get an adaptor for the hose running from the rad back into the block (requires ordering the adaptop)... but I was thinking of putting a fan controller here.. like this http://www.apexperformance.co.uk/cat...478f42ec8e01d4
For the oil temperature, it appears theres a block off on the exhaust side close to wear the turbo oil/ water feed the turbo on the block. Is this blocked off screw water or oil, and is this where everyone has oil temp read from?
So two questions:
Where are people pulling water temp?
Where are people pulling oil temp?
oh ye its a 180
Cheers,
Si
