Originally Posted by
Dermot
Why do people always assume headgasket failure = mixing oil and water..
Head gasket failure can =
Oil leak (In to cylinders or outside the block)
Water leak (Into cylinders or outside the block)
Mixing oil and water. either way
Or pressurising the water.
Also could be blowing compression between cylinders. or out between the head at the block.
Head gaskets can go in lots of different ways.
Also if its been boiled, 100% your head will be cracked. Which will also cause it to put pressure into the water.
But as said, it could be blocked rad, weak fan or fan not working? water pump not pumping? could be loads of things
