Originally Posted by
chrisb
no the more caster you run the quicker the feedback, but you can also have too much ase well
3/4 angle/lock simply that - from when the wheels are pointing straight to full lock in one direction count that as 100%. now if you turn your wheels to they are at 75% then you still have 25% of the lock left. (this is harder to explain than i thought lol)
the camber of the front wheels is all about the contact patch the tyre has with the road when the car is on angle or lock. if you run a crazy amount of camber so that the wheels are on full lock (100%) when the tyre is getting max contact with the road then the steering tends to go to that position
so if you run less camber so that at 75% of you achievable angle/lock the tyres contact patch is at its max the steeing will be smooth when at this angle (which is were you need to be to maximise speed threw corners etc, because crazy angles = slower forward speeds)
is not an issue having lots of camber it will just mean you will have to hold the steering at 75%angle/ lock instead of it naturally staying there itself
rather hard to explain but i hope ive got it accross in some way lol
