What's out there prefer a mines or something like that as not going for mad power
Thanks Rory
Thanks Rory
Don't think anyone can map mines.....! Iv a fcon vpro gold here if your interested.....!
:confused: at least give some reasons behind why they are a bad idea??(mines was just an example )i don't want to drop a grand on an ecu just to run simple upgrades, if the stock ecu is my prblem(see below there is no need for a full stand alone unit)
Bit out of the price range at the minute robbie but i may be onto you about other stuff
I just mentioned the mines as an example, i know their pretty agressive but as i was chatting to another member on here who had come across a very similar issue , and has been running a mines ecu for the last year with no problems, i copied and pasted this from skyline owners.... and although i wouldn't normally believe keyboard warriors i do think this is the same problem i'm facing,
R33 GTST flat spot. The talkings over!!!
Some months ago I became a newbie member to the Skyline clan.
I bought a 14 year old R33 GTST, aparently standard apart from a catback exhaust. i bought it with a misfire at 4500 rpm and was assured it was "plugs or something to do with the MPH converter"
Weeks later and having read soooo much "information" on various forums I booked the car in at the first of four! performace specialists that specialised in Jap cars and tuning. It would be wrong of me to name them, BUT the first three all failed to fix the problem, in fairness the third did tell me the problem but apart from fitting an after market ECU and re-mapping it couldnt fix the problem.
The problem was this;- Having fitted a big bore down pipe and de-cat I had a free flowing and free breathing engine. The AFM was reading so much volume that it hit max voltage and at 4500 rpm retarded the ignition and richened the mixture. This had the net effect of dropping 65 BHP off the curve and didn't re-appear untill 6000 rpm.
This is a list of things that were NOT the problem, as replaced or changed:
Coils
Plugs
AFM
Crank angle sensor
ECU
Ignition amplifier
Knock sensors.
The solution:- Re-map the standard ECU to ignore what the AFM is telling the ECU.
Rising Sun Performance in Alton Hants on 01962 773729 are the only company in the UK (I believe) that can re-map the ECU.
I picked my car up tonight and with 293 BHP it is the car that I've always thought it should be.............Awsome!
A very grateful thanks Richard and Damo, what a great drive.
Mines ecu's etc are set up to run 100 octane, and we have 95, on top of that a base map will only be so good as not every engine reacts to mods in the same way.
Why not try for an emanage or something if you don't want to go standalone?? Costs would be fairly similar though to a second hand unit,
Dont do it half arsed and then need to be replacing an engine.. Then there won't be much seat time without that...
Think i might be going that way, thanks for the input
mick a piggy back like you mentioned would be ideal but as you said it looks like power fc's can be got second hand for similar money,
I totally agree with you robbie but i don't think there's any need spending money foolishly either especially as i'm not trying to be competitive with the car
Rb25 power fc's are like golddust man,
