Joe your rushing it now! Why take it out to do a half arsed job
I it's gonna be 6 months again it's running get the engine freshened up and do it properly or you will have wasted 18 months prickin about with it
Point well made, paint is fucked and there is bubbles appearing everywhere in it. Its only happening in a few areas but it looks shite now :(
Gonna do it again, after I applied the primer I must not of scotched it enough for the paint to bite into it.
I agree with ya on this one.
He always does!!
Went out to check how bad the paint is and its pretty bad, im finding more areas that the paint is bubbling up, its only happening in a few areas but I cannot justify leaving it like that after the car being stripped for this long....
......so out it came.
http://i368.photobucket.com/albums/o...43155A3BE7.jpg
Spent ages fitting it by myself, only took 21 mins to remove it!!
Who would like to guess what happened when this broke???
http://i368.photobucket.com/albums/o...2973548648.jpg
So back the RB goes into storage :(
http://i368.photobucket.com/albums/o...4B053C8065.jpg
I think iv Saturday off, ill fit the rack and get the car into the shed again and check out exactly how bad the bay is. FUCK IT FUCK IT FUCK IT FUCK IT FUCK IT!!!!! Im going off to cry into my bottle of cider.
Cheers Nick, it would be cool to have loads of them over here!!!
Glad to see ya pulled it out again as Rory said looks like u were rushing it just take ur time and relax the time will be worth it
I went over board with mine and took it back to bare metal but the results shows of Patients get it good once and ul be happy
My heart ake might help ya a bit
http://i1198.photobucket.com/albums/...ps392a014e.jpg
Fair play Joe, would have been a shame to rush it at this stage when you have went so far.
Going to be the business when your finished :afro:
Right ok so, I have been weighing up the options of what to do with the bay, and instead of just fixing the areas that fucked up on me I started at it again. Say what yea want, Im not doing a half arsed job at this so for piece of mind id prefer to have the bay perfect. There is another few areas around the bulkhead that I marked when I was putting the engine in the last time so Ill be fixing them too.
I want there to be absolutely so rust on this car when it goes back together and in order to make sure of that iv stripped everything out of it in search of it. After I removed the carpet there is areas around where the roll cage went through the floor that are covered in surface rust, nothing too major but Im gonna attack it sooner rather then later.
http://i368.photobucket.com/albums/o...B8F3C44877.jpg
http://i368.photobucket.com/albums/o...835EFF2781.jpg
I managed to convince the mother to let me work on the car inside in the garage, its plenty big enough but the door is at a pure shite angle and is too narrow. It took me about 1 hour and 30 mins to get the car fully inside!!
http://i368.photobucket.com/albums/o...71B15FA834.jpg
http://i368.photobucket.com/albums/o...3D7A5D7051.jpg
http://i368.photobucket.com/albums/o...D8DC3213F5.jpg
And there it is, all tucked up at night.
http://i368.photobucket.com/albums/o...733B4714EA.jpg
And the fucker of a cat has made the car his bed!!!
http://i368.photobucket.com/albums/o...AD7012F0B8.jpg
So the search continues and more and more parts were removed, surprisingly even with all the bits removed from the car its still quite heavy!!!
Dropped the subframe to get it cleaned up and sprayed before it goes back on.
http://i368.photobucket.com/albums/o...A1B8648000.jpg
My parts room is starting to fill up very quickly!!!
http://i368.photobucket.com/albums/o...B5352C5FCA.jpg
And here is how it stis at the moment, the more I remove parts off the car the more rust I find but thankfully its still only surface rust!!
http://i368.photobucket.com/albums/o...D83CF3DAB4.jpg
http://i368.photobucket.com/albums/o...4715F8FB6A.jpg
So the time came to start back at the engine bay. I did consider just sanding it down again but it took forever the last time so I got the sandblaster out and went at it.
http://i368.photobucket.com/albums/o...5453B50538.jpg
http://i368.photobucket.com/albums/o...DFBDC972F6.jpg
http://i368.photobucket.com/albums/o...0674F3AA22.jpg
http://i368.photobucket.com/albums/o...2A5E8DB8F4.jpg
Really was a pain in the arse but saved a considerable amount of time, not yet finished but it wont take much longer. Next on the list is to go at the underside of the car, removing and treating and further rust and then a coat or two of schultz under the car.
Thats all for now, this shouldnt take too long to finish all this prep work as iv found the motivation I needed to get stuck into the car.
While its all cleaned of paint would you not spot weld some area's? like all the front end from the door hinges forward? And since you sand blasted it are you going to re seal the seams?
I don't see a point in seam welding a road car. Yea I will be using seam sealer before I spray it with Schultz
this thing is going to be so pissed off at not being driven that it is goign to send you into a ditch on its first drive back :P
Picked up a set of front hubs and brakes form a Skyline for the Cefiro(yea I do thow they arent compatable but ill be able to use the discs and caliper), originally I taught they were R33 but when I measured the disc they are 310mm in diameter and by checking the web it turns out that they are from a R34 GTT.
http://i368.photobucket.com/albums/o...DEFD490775.jpg
http://i368.photobucket.com/albums/o...6D16837C6E.jpg
Here they are compared to the R32 gtst brake calipers
http://i368.photobucket.com/albums/o...260EF502D3.jpg
I also got these 5 stud hubs for the rear of the car, since all the decent wheels are in % stud ill do a 5 stud conversion on the rear of the car.
http://i368.photobucket.com/albums/o...7E893A5941.jpg
My biggest wonder is when the time comes how will I get those front dics and calipers onto the 4 stud front hubs.
Wanted to have a few bits under the car clean so I sprayed up the subframe and a few other bits.
since the the Driftworks arms are orange I sprayed the subframe sky blue
http://i368.photobucket.com/albums/o...2063308F60.jpg
http://i368.photobucket.com/albums/o...0A16D1E87E.jpg
http://i368.photobucket.com/albums/o...E86B507A81.jpg
Then instead of painting the whole lot blue I picked an orange that was similar to the arms
http://i368.photobucket.com/albums/o...FD5C34732C.jpg
http://i368.photobucket.com/albums/o...236629AA00.jpg
Was bringing the car to the bodyshop again to spray the bay. I'm happy with how the colours look together.
http://i368.photobucket.com/albums/o...0D811AE2AA.jpg
http://i368.photobucket.com/albums/o...049C556EDD.jpg
Down on its wheels again and it's ready to go get painted (again)
http://i368.photobucket.com/albums/o...0F7C0CFAF0.jpg
Just waitin to get it trailered and finally get her finished!!!
Got her to the garage and into the bodyshop for paint again, second time lucky and I decided to spray it a different colour instead of goin MNP again.
We spent a good while sanding it down and getting as much of the old paint off as we could.
http://i368.photobucket.com/albums/o...4FDB7AADC8.jpg
http://i368.photobucket.com/albums/o...05EDE043A2.jpg
http://i368.photobucket.com/albums/o...09C5C0099B.jpg
So this is where I went home, Ken who's spraying the car was supposed to go home but then I get a txt late last night saying that he's finished painting it. Fucking delighted as he wasn't supposed to paint it till the weekend.
http://i368.photobucket.com/albums/o...B67A21C8F9.jpg
http://i368.photobucket.com/albums/o...52BCF645CC.jpg
He also Schultz'd the arches which I wasn't expecting, he's doing a top notch job guys if anyone is looking for work.
http://i368.photobucket.com/albums/o...9D41F27F00.jpg
http://i368.photobucket.com/albums/o...8C12484AF8.jpg
Iv to call into the garage tomorrow and put it back together, thankfully the time has come to get the engine back into this baby. The plan is to have it ready for my birthday next month.
Another weekend brings another step closer to completion :)
Most people would of spent the bank holiday chilling out with the 20 deg heat that was outside, but not me!! Ha ha. Decided to get stuck into getting the car back together, with the help of a mate we put the engine and box in together and managed not to mark the freshly painted engine bay :)
Firstly we gave the engine a quick clean with degreaser and its amazing how clean the block came up after we were done.
http://i368.photobucket.com/albums/o...84F2218796.jpg
Felt good to finally get the engine back in, its nearly been 14 months since I last drove the car and I'm itching to have it back one the road.
http://i368.photobucket.com/albums/o...07D9DB932D.jpg
http://i368.photobucket.com/albums/o...DAABEF4A01.jpg
http://i368.photobucket.com/albums/o...C1DD0C7153.jpg
http://i368.photobucket.com/albums/o...BC688921B6.jpg
Me taking over the workshop again!! lol
http://i368.photobucket.com/albums/o...F0F449BA34.jpg
Going to spend another while at it again this weekend, need to finish up the pipework in the bay, fit the diff and prop shaft, run brake pipes, new fluids and filters, run the power cable to the boot, fit fuel tank, fit every exterior pannel and paint the car. Jesys even just writing it down the list seems to be endless!!
Fingers crossed ill get it done, say a prayer for me guys!! lol
Well done Joey, needs a shiney rad in there,
Good progress Joe. Keep her lit!
Jesus this is really starting to take shape again! Fair play man I can not wait to see this finished.
Got a hole saw to drill out a new hole for the intercooler pipe, probably could of done with one that was half an inch smaller but it done the job.
http://i368.photobucket.com/albums/o...AD053BA728.jpg
http://i368.photobucket.com/albums/o...89E10BADF4.jpg
I got all of the heavy stuff done with the car while it was in the workshop, now it was time to bring it home to finish the last few bits off.
http://i368.photobucket.com/albums/o...8CC0D3F957.jpg
Also to keep the engine healthy I picked up these, Halfrauds to the rescue again!! lol
http://i368.photobucket.com/albums/o...55893AB417.jpg
And I picked up a set of wheels for the back of the car, gonna have to convert the rear to 5 stud to get them to fit but thats not a problem as iv a set of rear 5 stud hubs and bearings off a R34 GTT, just need to swap the rear hubs to get them to fit.
http://i368.photobucket.com/albums/o...FD56A035EF.jpg
http://i368.photobucket.com/albums/o...73BE3552BE.jpg
http://i368.photobucket.com/albums/o...ECEE2D3596.jpg
The light has me beat but I did get a good lot done to the car today. All the wiring inside is done and Iv the dash 70% put back in. Hooked up the jump leads and the ignition lights come on, the fan works and the fuel pump fires up. Another few days working at it and it should be ready to start up. With the pile of boxes full of parts gradually getting smaller it's finally starting to look like a car again!! Dropped my LCA's off today to have them extended by 25mm and to get them gusseted. I'm gonna have to wait until payday at the end of the month before I can afford to buy gear oil, coolant etc. And I'm also going to have to get the steering sorted, need to get a high pressure steering line made up as the HICAS setup was an absolute maze of pipes and I couldn't use the old one. In the meantime I'll just plug away at doing bits that don't cost anything to do, hopefully the rain will hold off while I get this stuff done. Collected the power cable from a R33 so I can relocate the battery into the boot courtesy of slithertooth and got an oil catch can. Just need to figure out where I'm gonna put it so it looks tidy.
Here's the video of the first start up of the car.
https://www.youtube.com/watch?v=PsdOzw9NzO4
After spending all the time putting the interior back together i'm going to be taking it all back out again. The reason being is some of the interior panels look like there starting to melt. So im taking the full interior out of the car and flocking all the panels, taking a few steps back again but it'll be worth it in the end as some of the panels are so bad that the residue is sticking to my hands when I take them away. Unsure weather I should go two tone or just keep the one colour for everything.
The outside of the car is starting to look complete again, I'm still a long way off being finished but I'm slowly getting there. Weather isn't really on my side and this would be so much easier if I had a shed.
http://i368.photobucket.com/albums/o...B258502578.jpg
http://i368.photobucket.com/albums/o...8B3DCB9486.jpg
I dropped my SSR Gartmaier's off to Glen @ Hubs Custom Finishes for a tidy up, as you can tell from the pics he done a pretty good job!!!
Before
http://i368.photobucket.com/albums/o...rgartmaier.jpg
After
http://i368.photobucket.com/albums/o...gartmaier1.jpg
http://i368.photobucket.com/albums/o...gartmaier2.jpg
http://i368.photobucket.com/albums/o...gartmaier3.jpg
Done a pretty good job IMO
Fuck them wheels came out savage:-)
Oh I almost forgot, Stevo was kind enough to provide me with this little gadget :)
http://i368.photobucket.com/albums/o...05AC6E314A.jpg
Pure gadget, does fuck all except give me live info on what the car is doing. Trying to figure out exactly where im gonna mount it in the car, as im flocking the dash I dont really want to have the bracket sitting on the dash. Where I am thinking of putting it is in the air vents in the centre of the dash as one side has already been macked out of it for a gauge that is no longer there and the other is as useful as an ashtray on a motorbike due to the fact that all the fins inside it are pointing all over the place.
http://i368.photobucket.com/albums/o...8749DE42F0.jpg
http://i368.photobucket.com/albums/o...206FAC12BA.jpg
As you can see above the places I want to put it. Deco pointed out it would be better to put it in the right vent as it will be easier to flick through the settings. He also recommended to put a gauge in the left vent but I don't have any gauges to fit yet. Iv more important things to do before I fit the Multi Checker anyway so I might pick up a gauge over the next couple of months and then work on fabricating them into place.
jaysus i haven't checked this in a while. I really can't wait to see this finished man. Such a cool car and so so rare these days...
Looking sweet man!
With you problem of where to mount the Multi Checker, have a look at this guys website. He does serious work when it comes to discreet dash work and there is definitely a thing or two to be learned just by looking at some of his posts!
http://broadfield.wordpress.com/
ah man don't even think about selling... you look to be so close with it now it would be a shame... someone else with buy it, finish it and post up pics on here for you to be jealous of... get at least a few months of pleasure out of it before you get crazy notions like that...
looks awesome joe! those wheels are gonna look so good on it, make sure your fitment is on point :p i'm still sorting out my front fitment/ride height
When I had started doing the strip down I always had a goal in my mind, If it wasnt necessary it got the bin. So one of the first things in my head to sort out was removing the HICAS and everything associated with the automatic gearbox.
So I removed the old HICAS steering rack from the car and replaced it with an S14 steering rack but straight away I encountered a problem, the pipes on the old rack ran behind the subframe, but the S14 pipes run up and over the subframe and would just look dirty and wrong, and not what I wanted to doin the way of keeping everything tidy.
A31 steering rack
http://i368.photobucket.com/albums/o...9A7106FE84.jpg
http://i368.photobucket.com/albums/o...DF7DD6612D.jpg
S14 steering rack
http://i368.photobucket.com/albums/o...B3E9F5DAE3.jpg
I decided I would run some custom steering lines so went onto demon tweeks and priced up a load of the little pipe connectors I would need, and the price of them was absolutely ridiculous. I was looking at getting a chasebays power steering reservoir re-locator kit and then lucky enough for me k1984w ended up breaking his 180sx so I bought the chasebays kit off him.
http://i368.photobucket.com/albums/o...00A2D8C1E0.jpg
Further on my quest to remove all the HICAS I started into the wiring loom to remove all the wires associated with the HICAS and the automatic gearbox (Iv quit smoking and I'm trying to find something to keep my mind busy).
So I removed the full interior wiring loom and started into remove all the stuff that wasnt needed. I also had to fix a load of loose wires in the centre as it looks like someone stole a radio and ripped the wires out while they were at it.
Box of wires
http://i368.photobucket.com/albums/o...D0BA3B6861.jpg
Let the lableing begin
http://i368.photobucket.com/albums/o...563D9DB8DC.jpg
I'm also going to be removing the engine bay loom as there is quite a few chopped wires that I'm not happy about, then ill chase the loom and see what wire is what as I'm going to retrofit the fuse box from the R33 skyline into the engine bay. The reason I'm doing this is because I'm running the power cable for the battery into the boot and if I ever want to jump start the car I want to be able to do it from the engine bay.
http://i12.photobucket.com/albums/a2...1/DSCN1846.jpg
Gonna try clean up the shed so I can get the car inside over the winter, collecting my wheels tonight so ill put the rear 5 stud hubs on the car and I'll see weather or not ill need to tub the rear arches in order to get them to fit.
Good man! Wires scare me.
