and a fine job you done Kevin!
anyone looking to have a jz fitted to a Nissan should get Kevin for the job!
any one have any more views as to which to go for 1jz or 2jz
I'd go 1j myself lad, i have a jzx90 which is savage responsive and I'm just starting a new project mkIV supra that's getting a 1j also.
Is there much of a power difference between a non vvt twin turbo 1JZ and the vvt single turbo 1JZ?
A lot of people seem to go with the single turbo conversion! Is this just for less lag or more reliability or what?? Its an expensive set up compared to SR but i suppose its the only way to go if your after for huge power
Neither, SR :)
it sounds like the 1j would be the best option
would the w58 box handle much lads
LS1/LS2/LS3
Simple, light, compact, more tuning parts available than any other engine in the world!
No need for:
aftermarket ecu
intercooler
boost pipes
expensive jubilee clips
braided oil feeds
turbo
ext wastegate
etc
and if you want more than 600bhp, then you can force feed it and head for even more power
Just a thought:cool:
