cheers man,
well i really wanted to move the Loom as alto it was pulled up over the metal guard the Wheels are so Wide that they where rubbing on the Rubber grommet where the loom enters the cabin, i had the dash pulled out but was too afraid to Go disconnecting the loom incase i break something LOL so after dieing with a hangover all day, i had a couple kopperbergs and at around 9 o clock at night i though fuck it just get it done!!
couple hours later and bobs your uncle Fannys your at Loom Mover never to be in the Way again :)
ready for surgery
https://fbcdn-sphotos-c-a.akamaihd.n...96351382_n.jpg
Cabin was in a bit of a state lol
https://fbcdn-sphotos-f-a.akamaihd.n...65494033_n.jpg
As it started note where the Bonnet release cable is, it was getting eaten by the tyre too
https://fbcdn-sphotos-d-a.akamaihd.n...30931002_n.jpg
so i disconnected the cable, re routed it through the engine bay and drilled a new hole higher up and connected it back up :)
https://fbcdn-sphotos-a-a.akamaihd.n...22385164_n.jpg
Got brave with the 3 1/4 whole saw bit and Drilled a hole for the loom
https://fbcdn-sphotos-g-a.akamaihd.n...64961430_n.jpg
you can see old hole Vs new hole,
https://fbcdn-sphotos-e-a.akamaihd.n...92943992_n.jpg
the finished Article
https://fbcdn-sphotos-d-a.akamaihd.n...64863301_n.jpg
For anyone who wants to do this go for it its a peice of piss!!
this is what you need to Disconnect the cable to the steering colum and the 5 conectors on it
https://fbcdn-sphotos-f-a.akamaihd.n...95492266_n.jpg
this top connector take the connector at the back of it,
https://fbcdn-sphotos-a-a.akamaihd.n...98456508_n.jpg
these two connectors on the Fuse board
https://fbcdn-sphotos-g-a.akamaihd.n...53021165_n.jpg
and another Black plug on the back of the fuse board,
https://fbcdn-sphotos-b-a.akamaihd.n...81258786_n.jpg
and this big white block connector
https://fbcdn-sphotos-e-a.akamaihd.n...11444546_n.jpg
then pull out your loom re route and plug back in 2 hour job just need to fill up the two gaping holes now :)
