mine did this all weekend.. gettin it sorted now for Sunday.. its dangerous could very easily do a Rb engine in!
i know chris thats why im doing
it . Iv
e the engine sitting on the floor with the sump off .just wondering where is the best place to get the fittings.also where is the best place to fit to the sump.some say at the bottom others say the top.with it been at the bottom there will always be 4 inches of oil in the return pipe
Its needed for any RB that will be doing track work. Its one of the main reasons for big end failure on RBs.
When they are used at high rpm for long periods the return of oil to the sump is slower then the feed of oil to the head so the bottom end suffors oil starvation.
Its also important that the external oil return is fitted to the correct side of the sump(same side as the turbo oil return) so that the vacume caused by the cranks rotation aids the oil return.
This is just rubbish. If you build a RB26 correctly then it will not keep the oil up on top. We have and still do work on many very powerful high reving RB26 engines and none have this mod all. In fact we have worked and machined parts for many world record setting RB engine and none of them had this mod.
If you need this mod then you need to look at other things first ? Like is you engine leak down excessive are you pistons rocking in the bore and letting the pressure in to the crankcase.
I have discussed this with many of the top tuners of RB around the world ( Abbey Motorsport, RB Motorsport, Top Secret, Power House Amuse, Mario, Croyden Racing Developments, and some more. They all agree with me. Build the engine properly and even with a Tomei up rated oil pump you can run 10000 rpms all day as long as your cams can do 10K.
The main reason for big end failures on RB engines is high mileage on old bearings or incorrect oil clearance / for oil grade.
Robbie
The master has spoken lol thats that sorted then!
so to be clear ur saying this mod is a waste of time and money.why are companys making this kit then.there must be some truth in it somwhere
If its a std factory engine without a broken ring land it will be fine but by the time it gets to Ireland it need to have new bearings and oil punp to allow it to run at hig revs all the time.
You can do this mod if you want but its a waste of money and not addressing the real problem
Robbie
