Looks great fella :)
Good man Gav, Seen her in Toweys at lunch time the last couple of day, looking sweet as, love the enkeis
Looking mint.
cheers for the comments lads ...
havnt really done much really except drive it an enjoy it alot . feels great after nearly being off the road for a year ....
few bits i did do ...
got my "other" set of koenigs back from sandblasting and painting ..
http://i804.photobucket.com/albums/y...802_145127.jpg
also picked up a pair of bridw brix2 recliners ....
http://i804.photobucket.com/albums/y...728_140202.jpg
http://i804.photobucket.com/albums/y...6587727575.jpg
cleaned it a little bit
http://i804.photobucket.com/albums/y...729_225355.jpg
interior alomst complete bar few small little bits ....
http://i804.photobucket.com/albums/y...730_103432.jpg
also picked up a set of avs model 5's 17x9s in really good nick ...
http://i804.photobucket.com/albums/y...731_105216.jpg
not much comming up for it not at least the next month or so but then it will be back on track ..
Looking wicked man. How can we tag Joanne on here?? ;)
The koeings are the right wheels for that car Gav
Lookin class man
You n noel needy bring them up to Donegal soon
I would if mine wasn't soon ta be in a million pieces lol
meeehh havnt updated this in ages but more for my self to rember what i have done .
fitted all four koenigs machine polished it and tidy'd it up a little
http://i804.photobucket.com/albums/y...925_181741.jpg
front has been lowered another 15mm since
http://i804.photobucket.com/albums/y...925_181443.jpg
http://i804.photobucket.com/albums/y...002_175416.jpg
also bought sard 550cc injectors on a rail. have since got plugs from a toyota and stared making a new little more hidden loom
http://i804.photobucket.com/albums/y...002_174942.jpg
havnt really done much more really except drive it and drive it alot !!
will be comming off the road id say next month for the winter and to get some tlc and lot of new parts!!
got a shotgun exhaust system made with tips to resemble a trust DD exhaust and moddded to sit super close to the floor and subframe to allow the car to run as low as i want . will get pics soon
more to come .
Them wheels Gav. Now don't bloody change them!!
Sucky sucky five dolla
Can't believe I have went through every page of this build :D lol Some build tho, a lot of time and effort put into this, not even going to mention about money! ha Fair play to ya, absolutely stunning looking machine! And wheels look the business, really suits it! Great work ! :)
havnt really drove nor done alot with it as its in the shed doin few bits but are limited as funds are low . . but i have bought slimline fans and surround and fitted them to the alloy rad . and done some general tidying up on it under the bonnet ! wiring ect . not much plans till after xmas really except lower it even more and rock around in it for a bit .
any way wanted to update the spec list for it also !
EXTERIOR
repainted vw ly3d
full kouki kit
Front bumper splitter and end cap
Side skirts
Rear bumper spats and center piece
Kouki bumper turn signals
Kouki spoiler
D-Max roof spoiler
raybrig headlights
lazy eye thingy
crystal side repeat's
crystal bumper lights
rolled arch's all round
SUSPENSIONS BRAKE'S AND WHEELS
Apex gen 1 coilovers
tein front tension rods
Japspeed bent type toe arms
Diff brace
cusco rear camber arms
5 stud conversion
moog ball joints
Full powerflex polybush kit through out
s14 inner tie rod's
s14 trackrod ends
poly bush's in lower control arms control arms
ploy bush steering rack bushings
Poly bush subframe bushings (powerflex)
s14 4 piston front brake's
driftworks braided lines all round
soild steering bushing
20mm front spacer's
65mm rear (extened ) wheel studs
fancy stud's
front strut brace
rear cusco brace
Wheels
SSR Koenig's
Front
18x9.5 et35
Budget 215/35/18
Rears
18x10 et 35
Budget 225/40/18
INTERIOR
apexi pencil turbo timer
nardi 350mm 50mm concave balck red stitch
Snap off boss
hand brake grip
fly off button
defi black face 60mm boost oil pressure oil temp and controller
Super fan controller and temp reader
japspeed short shifter
up rated fusion speaker's
alpine double din radio
Bride brix recliners
Recaro rails
Blitz dual SBC boost controller
ENGINE AND DRIVETRAIN
black top det
braided turbo lines
t28 s15 bb tturbo
front mount cooler and pipes
japspeed 4branch plated mani
Hpi split chamber elbow
all A/C removed including rad pump and lines
samco top rad hose with temp sensor
52mm alloy rad
slimline fans and cowling
dw oil cap
all multi layer gaskets
all brass non seize nuts
sard fuel pressure reg
oil catch can
light weight flywheel
exedy stage 2 3puk clutch kit
japspeed de-cat
Thrust DD exhaust
3"down pipe
2 way diff (unknow'n ) raito approx 3.9 ish
HEL braided clutch line.
z32 fuel filter
Cosworth 1.1mm head gasket
Cosworth rod bearings
Cosworth main bearings
Valve guides replaced
Valves reseated
New front crank seal
New rear crank seal
New Nissan spigot bushing
fitted up my alloy rad and twin fans !
http://i804.photobucket.com/albums/y...111_203441.jpg
and controller unit .
http://i804.photobucket.com/albums/y...111_203509.jpg
picked up a z32 over the weekend ! and have to get a plug off stevo this week !
http://i804.photobucket.com/albums/y...123_154101.jpg
got some toyota plugs and made a neat little loom tidy the wiring !
http://i804.photobucket.com/albums/y...123_154259.jpg
also picked up a works bell snap-off boss for cheap the other day ! internet image till i get ones of it
http://i804.photobucket.com/albums/y...oads/1911L.jpg
my thrust DD style exhaust . want to raise it up closer to the bumper slightly
http://i804.photobucket.com/albums/y...125_123024.jpg
sits nice and neat to go with the kit also and not stick out like most shotgun's
http://i804.photobucket.com/albums/y...125_123034.jpg
clean'd it a little
http://i804.photobucket.com/albums/y...116_155114.jpg
went to airside meet with my mate with his s15
http://i804.photobucket.com/albums/y...926_225342.jpg
will have another bit of an update over ther weekend !
Savage. Car is looking great man
Jeasus Gav there's some spec list on her now!!!
Lovely 180 lad some good work gone into it fair play
Cool car this
been gathering few bits for this over the last while !
picked up the cage out of keiths 180 when he broke it
http://i804.photobucket.com/albums/y...219_003618.jpg
picked up a plug for the z32 off stevo and hpi engine damper form keiths 180 also !
http://i804.photobucket.com/albums/y...227_211844.jpg
got some new gaskets off petko
http://i804.photobucket.com/albums/y...205_140941.jpg
done this
http://i804.photobucket.com/albums/y...206_021724.jpg
then this . gasket was blow'n between manifold and the turbo
http://i804.photobucket.com/albums/y...206_021915.jpg
then went all out and bought brand new 2871r
http://i804.photobucket.com/albums/y...3674451517.jpg
bought a power fc off stevo cuppla weeks ago !
http://i804.photobucket.com/albums/y...201_165455.jpg
all the bits there for mapping now except for the sard to nissan injector plug's which should arrive soon ! . fitted up the 2871r tonight finish it off tomorrow eveing and book it in for nct and book it in for a map !
Pull your finger outa your arse boy
where did ya get the braided pipe ?my mani is always melting the pipes i put in and cant get a braided one
good work gav, will be savage to go wen mapped. @rpsdan should be able to get braided pipes off pirtek r any hydraulic places.
Good stuff Gav, sexy few bits ya have gathered up there! Who's doing the mapping for ya?
havent updated this in a good while really and should more often tbh to try keep the site goin .
got a nct on it
http://i804.photobucket.com/albums/y...5497959127.jpg
lowerd it and all after again
http://i804.photobucket.com/albums/y...502_183702.jpg
http://i804.photobucket.com/albums/y...502_184120.jpg
went to killarney for rally of tne lakes met some cool people and took some photos !
http://i804.photobucket.com/albums/y...504_182410.jpg
http://i804.photobucket.com/albums/y...504_182435.jpg
http://i804.photobucket.com/albums/y...518_154234.jpg
went to noelb's charity show and shine over the weekend for 1life and console part of the mnc drive4charity
http://i804.photobucket.com/albums/y...3163633112.jpg
http://i804.photobucket.com/albums/y...3164459710.jpg
http://i804.photobucket.com/albums/y...3207258799.jpg
http://i804.photobucket.com/albums/y...3207266146.jpg
havnt done a huge amont with the car mechanical wise bar drive it alot !
did how ever buy an new 60mm alloy rad as mmy own was leaking fitted up with my twin fan set up and all
http://i804.photobucket.com/albums/y...3464567252.jpg
saving up afew bob at the mo to get new toemi high lift cams 256degrees and heavy duty valve springs and retainers !
also gathering some panles/areo for it for its full respray in theautum/winter ! but thats under wraps for now !
geting full custom tuck loom made for the bay shorthy as goin a bit fancy with that side of things ....
more to follow ;)
It was my show that made your car look awesome. You forgot to mention you won a trophy......"hardest parked"
Lovely looking car, great style with some lovely bits. Just not mad about the yellow rear lights.
looking brilliant gav. that house in the first few pictures, is that where father ted was shot? hahahah
Tomei 256 cams are drop in . No retainers or springs needed ..
So save yourself money just buy cams . There great cams ..
Nice 180 . Love the wheels
I have 256's and have to now replace springs and retainers. Id rather spend the money and do it once an have a bullet proof engine. Which is what I'm doing now. But gav's a tight arse so he'll prob turn it back to a de to save money lol
Typical enough it'd happen to me but saying that I do like to rev the tits outa it
Wow really havnt been on here in a long time ! Have done nice few bits with the car in the last while ! Must add photos later tonight to show whats what !
got for it
billion power steeing tank
r33 rear brake setup
alloy coolant tank
bradied fuel lines
new 60mm alloy rad
Gk-tech rocker stopper arms
gk-tech water neck spacer ( for water temp sensor so no cut top hose)
New down pipe
flexi-decat
Oil catch can and pipe work
cusco brake master cyliner stopper
new rear braided brake lines to suit brakes
ganador mirrors
new front coilover topmounts .
Plans for the next few weeks is get it mapped and nct'd both in febuary and gather up new aero part and new rims before it goes for respray in march
Finish that respray quick for the Crew OneSeven stand at auto heroes ha Wouldn't mind doing the one in march
