Well lads it's time to start buyin bits to rebuild my sr20 so I'm looking for acl race grade bearings
0.5 mm over size pistons and suggest any other bits ye have I'm going to need I just can't think of them :huh:
top mount manifold and wastgate
get the bearings from whoever is polishing ur crankshaft!!
I use murphys engines in cork, and have never had a problem with anything they did
Up to tdp and get a sr217
well i've got a good standard sr with a hks head gasket, hks cams and have a 2871r and got 400hp.
get them to check the crank and give you bearings to suit, either hone or over bore which ever you want to do, deck the block and skim the head reseat the valves and new stem oil seals. then you should be mint
did you conpression test it yet lad?
