Need one of these as one of mine failed. Anyone got one laying around or know where I could get one?
01-04-12, 20:10
robbie@tdp.ie
Quote:
Just use std billy. The SR20DET Splitfires are unreliable. With the correct plug gap there will be no problem.
Robbie
01-04-12, 20:14
driftescort
Quote:
Robbie
Will it be ok to fit STD ones with my map Robbie?
01-04-12, 20:15
robbie@tdp.ie
Yep.
Robbie
01-04-12, 20:22
driftescort
Yep.
Robbie
Lovely! Any experience of the TPS sensor causing a miss/hesitation? I had this today and the only way to fix it was unplug the TPS sensor? Suppose I should replace it?
01-04-12, 20:28
robbie@tdp.ie
Yep a dirty track on the TPS can cause extra pump effect fueling. Try replacing it. You will need a consult cable to correctly set it.
Robbie
02-04-12, 06:25
driftescort
