Page 1 of 14 12311 ... LastLast
Results 1 to 10 of 136
    Pro Driver Dennis Healy's Avatar
    wicklow
    Default clearout, nissan, altezza,ae86, 1jz, rx, supra, loads of parts
    http://s755.photobucket.com/albums/x...arout%20parts/
    heres a link to pic of all the parts, if you need more let me know
    Swirl pot, syntec filter bosch 044 pump, braided lines and all fittings 400sold
    No make s13 sr20 intake manifold with 80mm throttle body 300
    S15 works 9 rear quarter arches 250 SOLD
    Sr20 3 core copper rad 150 sold
    Alloy power steering and alternator pulleys 40
    Sr adjustable actuator 40 sold
    Sr fuel rail adaptor 20
    Top feed injectors blue 450cc 250
    Gtr fuel pump 100 sold
    Tre performance fuel pump 60 sold
    Sr s/s exh manifold 80 sold
    Sr s/s exh manifold with pipe for external wastegate 120
    Sr20 piston rings new in box SOLD
    Garage sarus 180sx ecu
    Coilpacks and looms x 3 50 each
    Sr exhaust gaskets mix of them
    Power steering pumps x 2 30 each
    Alternators x 4 30 each
    Td06 stainless heat shield 15
    S14 zenki bonnet 70
    S14 zenki wings 40 each
    S14 zenki side lights 20
    Greedy 100mm intercooler 250 sold
    Sr20 n/a stainless manifold and pipe to cat 100 sold
    S15 standard side skirts80sold
    S15 rear bumper 80 sold
    tein superstreet rear coilovers S13 180 sold
    S15 440cc injector 150 sold
    je 87mm pistons sold
    gtir sunny engine took apart sold
    gtir intake manifold
    altezza bits
    Cusco coilovers 400 sold
    2 rearTein coilovers 200
    Tein edfc 200 sold
    Hks induction kit 150 sold
    Cusco underbody rear brace 100 sold
    trd under front brace 100
    Ganador mirriors 150 sold
    Starters x 2 50 each
    Lexan windows 400 sold
    Carbon door skins, replaces orignal 100 each sold
    Wexican front bumper x 3 200 each sold
    Wexican side skirts x 3 170 pair sold
    Wexican wide arche kits x 4 200 set sold
    Bootlids x 2 100 each
    Headlights pair 160
    Rear lights pair160 passanger side sold solod
    Standard rad with fans 80
    Passanger wing 80 euro
    Drivers wing 80 sold
    Bonnet 100 sold
    Mirrors 30 each
    Clear side repeaters 15
    Trd recliner seat for altezza 300
    Front doors 100 each
    Rear doors 100 each
    All interior parts
    Shell sold
    Loads more altezza bits
    Miscellaneous stuff
    Nardi steering wheel 70 sold
    Nardi personal steering wheel 70
    Supra momo steering wheel 80
    Nissan boss 50 sold
    Oil catch can x 2 30 each
    Apexi exhaust butterfly and cable 60 sold
    Hks mushroom filters x 3 20 each
    Grayston bonnet pin kits x 2 10 each 1 sold
    Omex rev limiter 50 sold
    Apexi boost control valve 20SOLD
    Blitz sbc valve 20SOLD
    Hks boost solinoid 20
    Ikea formula gear position indicator for sequential shifter
    Timex oil water boost gauges, no sensors or wiring
    Greedy boost gauge sensor 20 sold
    omori white oil pressure gauge 40
    Hks boost gauge sensor 20
    Juran rad pipe temp adapter 36mm 15 sold
    Braided lines for supra altezza soarer aristo 40 sold
    Harness hooks
    Evo 7 brembo calipers front and rear 200 sold
    Supra rear calipers 100 sold
    Different rate 60mm coilover springs
    Apexi rsm 100 sold
    Hks vein pressure converter
    Aristo 161 headlights 150
    Supra mkIv rear lights 100
    Ps13 fibreglass panel to replace back seats 30 sold
    Few meters of braided brake line
    4 x spacers 5x114 20mm80 sold
    1jz starters x 2 50 each
    1jz coilpacks x 6 sold
    Carbon kevlar momo bucket seats, side mount x2 200 each sold
    AE86 bits
    techno toy steering knuckles new 100 sold
    cusco front anti roll bar 120
    sold
    30mm t3 rcas sold
    Trueno vented frp wings 160 sold
    Trueno bonnet 100 sold
    Trueno bonnet with back stays cut out 70 sold
    Trueno headlights, covers and motors,metal that hold lens in rusty sold
    New lower arm strenghtened with bush and ball joint 70 sold
    Pollybushed 4 links 40 sold
    Standard side skirts 80
    Trueno headlight covers 20 each
    Power steering knuckles 70 sold
    windows for booter
    rear TRD arches
    interior bits
    axle casings
    early spec half shafts
    loads of ae86 bits
    DIFFS
    Altezza
    4.1 welded x 2 150 each
    4.1 torsen 150
    4.1 torsen 150
    6 x altezza half shafts 30 each
    4 x is200 half shafts 30 each
    Nissan
    4.1 sold
    3.7 welded 6 bolt 100sold
    3.9 welded 6 bolt 100sold
    4x 5 bolt half shafts 30 each
    6 x 6 bolt half shafts 30 each
    Rx7 FD 3.9 open diff 150
    Supra jdm TT manual diff 3.3 250
    Chaser soarer half shaft 30
    shells
    rx7 shell doors bonnet bootlid rear subframe
    caged altezza shell sold
    half caged altezza shell
    have pics of bits if anyone needs
    loads more there will keep adding to list as i go through it, thanks
    call me or pm 087 9847625
    link to pictures at top
    Limerick
    Did you go up with a big trailer to Ffrenchie's LoL
    Drift Shed Doofer's Avatar
    Wexico
    Are the 3:7 and 3:9 Nissan diffs in the casing? What back plate do they have and do they have the ABS sensor... Thanks
    FIND AND LIKE THE DRIFT SHED PAGE ON FACEBOOK.. THANKS !!
    wicklow
    Quote Originally Posted by Kruizer View Post
    van trailers an jeep ha
    wicklow
    Quote Originally Posted by Doofer View Post
    text ya there, will check in morning
    di Member hoopsbhoy's Avatar
    Sep 2010
    Are the spacers bolt on and would you sell 2?
    Wexico
    Quote Originally Posted by Dennis Healy View Post
    Sound Ted
    wicklow
    Quote Originally Posted by hoopsbhoy View Post
    yea bolt on, 40 for 2
    Sep 2010
    Default Spacers
    I'll take two spacers, Mite take another few bits to, have to check what I still need and if I can get em collected where in Wicklow are you based?
    Cheers
    Michael
    di Member Deco84's Avatar
    Oct 2009
    Dublin North/West
    any pics of the nardi and personal wheel will they fit a 180?
    We can't stop here this is bat country
