Results 1 to 10 of 23
    Default Toyota Chaser JZX100
    1996 JZX100 Toyota Chaser for sale:
    current Mileage is 115,000 Kilometers
    Dmax-drift coilovers all round
    Work CR-KAI 18" wheels
    Splitfire spark plug leads
    HKS panel filter
    stainless cat back exhaust
    Where do i start lol, car has had preventative maintainence done and major service work in the last 1k kilometers. All genuine Toyota parts have been used, the list of work that was completed was:
    Timing Belt
    Water Pump
    New coolant
    New Thermostat
    Aux belts replaced
    New drop links front
    New drop links Rear
    New ARB bushes Front
    New ARB Bushes Rear
    ATM fluid and filter Changed
    Oil Filter and oil Replaced
    New plugs
    New Pollen Filter
    Brake pads Front
    Brake pads Rear
    Brake Fluid Replaced
    New Rocker Cover gaskets replaced
    Front Lights replaced (the old ones were misty)
    Included in the sale is the full kit to convert the car to manual. The kit Includes:
    R154 Gearbox
    R154 Remote Shifter
    Supra Prop
    Clutch Master Cylinder
    Clutch slave Cylinder
    Clutch cylinder spacer
    New Gearbox Mount
    New Clutch
    New Genuine Toyota Flywheel
    All the bolts needed
    New Genuine Toyota Clutch line (both rubber and hard pipe)
    New Genuine Toyota Clutch fork
    1jz Bell Housing
    pedals set
    TRD 2 way Diff in casing
    Labour on the conversion is 350-450 for anyone that wants it done.
    I have a few spares to go with the car and some extras:
    New Cusco front camber arms (over €500)
    Spare Front head lights
    Original Toyota Mat set
    Rear brake pads
    Spare ac control bulbs.
    Mechanically this car is 100% perfect, drives well and its fun more to the point. I will not split the manual conversion, the sale is for the complete car and conversion as a whole.
    Price for the lot is €7,500 ono.
    I can be contacted via pm, Ideally not looking for swaps.
