Results 1 to 10 of 11
    Default Electrics.. Clocks..
    The loom has seen better order.
    Few things dont work, but the main priorities for now are the Tacho and the speedo.
    Clocks dont work; Fuel and Temp do work.
    Any ideas on how i would make an attempt at starting to sorting it out?
    wires are floating around down by the pedals.
    Thanks.
    take out the clock an look for loose or broken connections dude...jus strip back the dash on the driver side an have a nose bout to see can you find the prob
    yea, if its not lack of connections it may be loose/broken ones.
    and only the left light pop's up
    whats the story with earthing wires? i have a random earthing wire just lying there, its currently sitting in the door card pocket, god knows where it cam from.
    there should be a thick enuf one goin from on the inlet mani to the chassis leg rite beside the fuel filter an few more round the engine bay...ill check where all mine are later an tell ya.
    Yea the only one i took a quick look at was the inlet mani one... and it wasnt even bolted in
    the sheer amount of wire's under the steering wheel is daunting as i dont have a clue what im at :L
    ill check all the grounds in bout 20mins or so an ill take pics of them be easier to show ya then explain
    well only if its no hassle
    ill not be home till later to check em anyways.
    i took a load of pictures yesterday but the laptop is being gay and not letting me upload em
    thanks man!
    jus have few pics here now of the ground in the engine bay jus sortin them now
    rite heres the pics all the grounds are circled in red
    this is under the slam panel in front of the battery
    this is at the back of the head jus on the top the firewall
    this ones under the slam panel in front where your air filter is
    these two are on the inlet mani beside the clutch master cylinder
    this is the one on the bottom of the inlet mani runs to the battery
    this ones on the driver side strut beside the coolant over flow bottle
    hope that helps
    you my friend are a legend!
    couldnt of asked for more!
    i shall go home and check to see if they are all there. and ill keep you posted
    thanks very much!
