What other mods are on it?
You cannot run 1 bar on either the standard fuel pump(would cause severe underfueling, knock, ignition retardation) or the standard turbo. The standard turbo will fail prematurely if running at 1.0 bar any length of time.
Also if you are trying to run higher then standard boost then you need a colder heat range spark plugs.
