I wouldn't recommend using a t-peice for the front brakes.
A non ABS master cylinder has 2 outlets for the front, one for left and one for right. This gives the required force and pressure for the larger front brakes.
It also means that if you damage a brake line or have a leak you don't loose front braking completely as you would using a t-peice/splitter.
