Results 1 to 10 of 11
    Default sr20det cut out prob
    rite prob is wen i come to a quick stop an dip the clutch before it stops rollin
    the car cuts out an now it does it in 2nd wen im slowin down normal if im
    comin from 3rd into 2nd wen im still holdin the clutch to put it into 2nd it cuts out
    anybody got any idea why it mite be doin this its gettin fairly annoyin
    Thanks
    Dara
    common problem im silvias and the like, u need to get yer heel toe shifting on.......
    i thought it was the afm, but common problem happens to me to lad
    sometime it happens when i come to a stop and clutch is in
    just starts cut out but then it just revs up a bit
    possible boost leak imo
    jus happens me in 1st or 2nd wen the car still rollin tis pain in the sack...gona tryin cleanin my afm an the idle air control valve thing.
    let us know how you get on ted, i be intressed to see what it mite be
    razzer well boost holding ............
    i have the same problem with my car..the afm is dodgey..id say thats your problem more then likely!!
    did you replace it ted
    Iv heard of this happening to a lad before and i think it had something got to do with his dump valve or in or around that aera............
    Quote Originally Posted by S14a johno View Post
    i cleaned it..it improved it alot but its still there a small bit!!
