Results 11 to 20 of 28
  1. #11
    Quote Originally Posted by alan180sx View Post
    lad is it much hassle any pic of wat has to b changed
    Timing chain has to come off take out the inlet cam and change the sprocket and reset the timing, Do you still have the 180 engine you can get the sprocket off it, you'd have to get a mechanic to do it unless you can set the timing on a car..
  2. #12
    di Member alan180sx's Avatar
    is that it lad just change the inlet cam sprocket for the one on my old 180 cam sprocket and time it up again.
  3. #13
    As far as i know yes that will be it but dont quote me on it a tunner will tell you..
  4. #14
    use a v-tec controller to control the vvt quicker spool and better low down power
  5. #15
    Use a v-tec controller?
    The Nissan vvt has no electronic connection whatsoever and is not controlled by the ecu so there is no way a controller could effect anything.
    The vvt is not the only difference between the red top and black top.
    The head is a different design, some of the breather and cooling take off from the block are different as well as the obvious turbo and intake manifold differences.
    What is wrong with the old engine?
    www.inoc.ie
    Irish Nissan Owners Club
  6. #16
    Keep the VVT lad, more low down torque out of it, 14 and 14a are almost exact same engine bar a feew small things, EGR etc, but ya might aswell get the correct loom and keep the vvt
  7. #17
    di Member NIALL JZX's Avatar
    tipp
    how, wat, v-tec controller??
    if ya swappin ya prob have to throw in the engine along with loom an s14 ecu... make sure ya no which ya have as s14 and s14A ecu are different...
    formally drifter
  8. #18
    if you re putting any s14 or 14a(both have vvt) engine in you will need to change
    engine
    engine wireing loom
    ecu
    air flow meter
    inter cooler pipeing
    interior rad pipeing from s14/a
    to be honest id hold out and get a none vvt engine as its just a strait bolt in job unless you are getting the vvt engine very cheap
  9. #19
    Quote Originally Posted by nissan_doctor View Post
    bullshit the vvt solenoid has no electrical connection??? It takes a 12v supply and that 12v turns on the vvt you could wire the solenoid in with a permanent feed but i am sure you would want to turn off the vvt at 5k like the standard s14 so you could use a VTEC controller to control the vvt but honda use different electrical system to nissan so pop on a relay and off you go or if you have a stand alone ecu with outputs on it you could be programmed in to switch on the vvt solenoid.
    Yep VTEC your s body lol
  10. #20
    What are you jibbering about? The Nissan vvt is operated solely by oil pressure, the revs/oil pressure rises, the vvt sprocket activates. There is no solenoid!
    You've just written a whole post containing nothing based on fact whatsoever!!
    www.inoc.ie
