Results 1 to 10 of 50
Thread: Budget builds?
    Ooohh and lads, i have the car im doing but just generally can sub 2k be done or what would people be buying and doing ect
    di Member bart's Avatar
    laois
    stevo your car will be under 2k......
    Quote Originally Posted by bart View Post
    Yup should be ted, Just Jap recession buster slider
    easily! if i ever have enough money spare to waste on a track car il be looking for a standard 200sx, diff welded, springs chopped or cheeeeeeeeap coilys, a seat and thats it. same aplies if i find an omega! 1500 i say it can be done no bothers!
    Cill Dara
    Yeah you could have it for under 2 grand, don't expect mental power but in all honesty most lads are doing track days now and you don't need much power for that! Get some non-turbo (won't break your heart) with a good engine for under a grand and just put red stuff pads and hydro handbrake and away you go! All the other bits after that are just extras!
    €1500 to €2000 can be done easy but if its for comps then most of your cash will have to go on a good cage.
    After that, cheap springs, washers on the steering rack, seat and harness and your done.
    @ericosullivan
    try,a,mv6,omega,or,a,carlton,cheap,loads,of,power, and,reliable,not,to,mention,if,u,hit,something,tha t,will,be,worse,off,than,ur,car
    Yup hope to build my mv6 for under the 2k, yeh Eric cage will be the biggest spend after the car!!
