Results 1 to 9 of 9
    Default suspension set up
    any 1 no how much it would cost me 2 get my suspension set up for driftin in my 180sx i have all top mount and bottom mount adjustable coilovers and camber arms front and back.....or does any 1 no the setings
    Administrator Administrator's Avatar
    Different settings suit different drivers and power levels. Give TDP a shout
    di Member sil80drifter's Avatar
    Laois
    or wes at wkd
    Default thanks
    thanks lads
    Greystones, Wicklow
    Fairly basic setup but ya could try this if your starting out.. Meant to be easiest to learn with!
    FRONT:
    2.5 deg negative Camber
    7-8 deg possitive Caster
    0 deg Toe
    REAR:
    1.5 deg negative Camber
    0 deg Toe
    this what im running on my ps13
    FRONT:
    7 deg possitive Caster
    0 deg Toe
    REAR:
    0 deg Camber even tyre wear and lots of grip
    0 deg Toe
    di Member Micko's Avatar
    Give the mike deane a shout down in cork, know its a bit to travel but i couldnt praise his work enough on the set up on my car and the bros s14.
    Cork, Ireland
    Quote Originally Posted by Micko View Post
    Agreed..............
    Stupid Question but any of ye playing Forza 3, do ye use the same suspension set ups on yere cars?
    TEAM MANFOOT
    Roscommon
    whers the usefull post by polo gone to???
