Results 1 to 10 of 13
    What spec are you all running, ecu's etc? Reason I ask is that Sr20 coils do not give trouble in general.
    If you are all running a few stage 1 mods(fmic, pump, 0.8/0.9 bar boost, plugs etc) the problem could well be the cold air, being much denser then warmer air, throwing the air/fuel ratios off from what the maps were set up for, Meaning that you are underfuelling rather then misfiring.
    www.inoc.ie
    Irish Nissan Owners Club
    my own spec is FMIC grade, 7 plugs, air filter, decat, downpipe, catback, standard ecu, @hunt s15 does your boost spike over 1 bar aswell and does it hold back on full acceleration?
    sorry for the thread hijack
    Know of 2 s15's been broken...
    It may harm your defence if you fail to mention modifications which you later rely on to overtake
    ive had a few s15s up here wid coil problems,, one was coilpacks,, one was the coil harness,, s15 coils are much slimmer
    i have a set s15 coilpacks like new if your interesed
    thanks anyway but have splitfires on order now any way. def coil pack not underfuelling only one coilpack went on me, when i jump started it, went and bought a battery after the damage was done, spec is fmic, hks f con v pro hks plugs, top mount td06 20g, runnin bout 1 bar
    My Phat Girl hunty_sideways's Avatar
    @s15 spec r yup its does example: power power chuck chuck BANG and away like the clappers then
