Page 21 of 22 FirstFirst ... 1119202122 LastLast
Results 201 to 210 of 216
Thread: zenki s14
  1. #201
    I've had my eye on this a while now, The attention to detail on this build is un real..
    Well done man , keep up the good work
    ConorF
  2. #202
    di Member kenny046's Avatar
    Quote Originally Posted by decobyrne106 View Post
    Thanks dude! Any updates on your car I haven't seen the thread in a while
    went for mapping and needed a few bits to finish the road map, have it all sorted now juts need to book it in and its done got the quarter put on my navan spats and sprayed the boot floor so just small updates, ill do a big one when its mapped,
    keep this thread alive man looking good
  3. #203
    di Member seanie R.33's Avatar
    Savage work deco, makes me wanna go out nd do bit sandin but im too lazy
  4. #204
    i like cake
    @Conor sr_20 Thanks for the criticism dude I appreciate it! Ill try keep the thread updated with pictures as much as I can rather than text on its own, try keep it not boring everybody just looks at the pictures in a book afterall yeah? :P
    @Kenny046 Thats the shot the navan spats should make all the difference to that car! Will tie in the wheels and all with it. Good lad!
    @seanie R.33I wouldn't blame you its not easy but it won't do itself! :P The paintjob on my car isn't brilliant by all means, but atleast the roof doesn't have bad lacquer peel and charred paint and no matt black parts anywhere! :P There is a few mistakes on mine and atleast I know if I were to do it again, pay more attention to 'x' and 'y' .
  5. #205
    i like cake
    Didn't do much to the car at all today. Just looked at a few things and planned my next approach. Gotta closer look at everything else too.
    Got these pics to show you guys, heres the japspeed extra lock tension rods clearance on lock, brilliant! Absolutely brilliant amount of space, you can see that if it was an orginal straight adjustable tension rod, the tyre would need to be stretched like mad just to clear it and probably eat the rim first anyway!
    So few things I gotta do still.
    -Lengthen the tension rods because I have them a bit too short atm, theres alot of caster going on :P
    -Lengthen my Lca's more because they can take alot more and it should help clearance on lock if I do aswell
    -Fit my front whiteline anti roll bar, undecided if I will or not because some don't use them and some do depending on how you set up the suspension characteristics and by the way I want it, I might not need it!
    -Put in the gearbox poly mount
    -Put up the exhaust
    -Drop the car on the ground and drive it out and make it move around a bit, bring it back in, up in the air on wheels and check all nuts and bolts are tight!
    Thats just for now anyway then plan to get the car sent off for alignment and finish off the other little jobs. Give her a clean of all the dust, put on a few shtickers and drive her on up against a big wall sideways Aaaaalmost there, aaaaaaaaaallmost
  6. #206
    Jun 2012
    Serious work .. keep it up ..
  7. #207
    i like cake
    Really late, wanted to update. This will do for now
  8. #208
    i like cake
    SO after much fiddling around with the suspension, making the lca's longer and rough camber setting up and blah blah etc, she sits on the ground now waiting for alignment, exhaust, interior fix up and im in 2 minds wether to put the kouki spoiler on it. Still needs alignment and spacing at the rear to make it look less gay but its not so bad. Got a lend of a good camera the other day and decided to let the inner photographer out, even though i never tried it before :P
    I dunno how long it will be till i get it fully finished because im up to my ears atm, hopefully i can get around to it because im dying to drive it! Transport is killing me though as it always has. Would have loved to do superdrift on the 20th.
  9. #209
    Fair play to sticking with it, its looking great. Iv lost all interest in the Cefiro, may try to build the motivation back up.
  10. #210
    Zenki addict lady89's Avatar
    May 2011
    nom nom nom
    Click Project Thread
    Click HERE for my blog
