Results 1 to 10 of 13
    its not low enough!
    i always thaut neos had steel blades an not ceramic?! good to no !
    MEATH
    There a kinda mix of ceramic and plastic :confused
    They still don't take boost either way, you'll find the impellar bunged into the cat core like all the rest
    All RB turbos are ball bearing, hence the Oil Feed banjo restrictor being so small.
    RB Neo Turbos have a plastic compressor wheel and ceramic turbine wheel, this is why they spool faster than the earlier turbos. They also have a bigger exhaust housing than other RBs. You should get 1 bar safe on any RB turbo.
    di Member GTSr32's Avatar
    no not all RB turbos are bb at all..!
    in a perfect world id get a RB25 neo turbo redone with steel internals ... But a normal rb25 with steel internal will do you nicely...
