top work man! what size tubing did you use to build the bumper bar?
So had my mechanic at the engine, got it back from machining last week and spent the day honing and cleaning block, Assembly started today so spec is wossner 86.5mm pistons, Manley con rods, arp main and head studs, acl bearings and thrust washers, cosworth 1.1 metal headgasket, all new valve oil seals and valves grinded in, tomei rocker arm stoppers and adj cam sprockets. Waiting on oil pump and few bits so hopefully be fully together soon.
