Results 1 to 5 of 5
Thread: S13
    Aug 2010
    Default S13
    I have limited access to the net at the moment so bare with me while I update the thread with parts and prices and pics;
    CA18det engine, gearbox (very tight) loom and ecu, with nearly new exedy clutch, flywheel needs skimmed. In great condition and can be seen running before taken out of car. €700 - May sell separately if it sells quicker that way!
    All adjustable arms for rear. Upper and lower control arms and toe arms €70 a set
    Subframe - painted red with solid alloy bushes €100
    Aftermarket Polybushed anti roll bar €40
    Struts front & rear brand new (look to be cusco???) €120
    Magnum FIA approved but out of date fixed back seats €250 the pair
    Monster dish steering wheel and boss €100
    Rear S14 na hubs €50
    Driftworks Hydro and Lines €120 has only seen 1 days use!
    Welded diff (wont no ratio until I take it out will post price then)
    €50 for the homemade turbo back exhaust - not the breast now to be honest
    HPI Front mount with piping €250
    HKS adjustable actuator - has been modified - excellent cond. though - €50
    Almost sure its a T28 from 14a - will double check when take it out €130
    Short shifter - dont know make €40
    skid wheels - 4 16" advans sprayed white and before that green, 70% tyres - €100, 2 17" cheapo multi spokes white with good tyres €70, 3 standard S13 15" rims - €70 - or the lot for €200 and will throw in a some good part worns
    will try get rest up later
    http://tyresdublin.ie/
    di Member pepsterx's Avatar
    Mayo
    I'll take the hydro off you lad you have a pm
    Dublin
    Sent you a PM chief
    Team Chihuahua Kruizer's Avatar
    Limerick
    What make are the arms, any pic's of the wheel ?
    Aug 2010
    Dont know what make the arms are - They are much chunkier than the driftworks stuff i've seen though. I will throw all pics over the next day or two when I get a chance. Only have the net in work at the moment so have limited access
