Results 11 to 20 of 23
  1. #11
    Pro Driver
    plug out the lamda sensor and see if it reves then!!!
  2. #12
    Jan 2011
    afm maybe?
  3. #13
    Prominent Member mickel's Avatar
    Leitrim
    Quote Originally Posted by jimjim View Post
    afm maybe?
    the afm was changed on it before it's last run in mondello
    we thought it was sorted,brought it to mondello and
    it ran perfect for the first lap,then started limiting at 5k again
    new plugs fitted yesterday,coilpacks changed for a known good set
    o2 sensor changed,actuator changed/doesn't seem to be any boost/vacuum leaks
    any more thoughts lads
  4. #14
    Is it actually limiting at 5000rpm? or just revving to 5000rpm and not revving any further? Has it normal power up till 5k? Whats the spec of the car?
  5. #15
    Feb 2011
    leitrim
    Quote Originally Posted by Dermot View Post
    Its revving to 5000rpm, but wont go any further when its under a load
    Power seems normal, it has fmic. s15 turbo, walbro, stainless elbow, thats about it really. Im running outa ideas big time
  6. #16
    Feb 2011
    leitrim
    Cheers lad, tried dat but no joy
  7. #17
    Quote Originally Posted by Aidan D. View Post
    i had that before with my rb20det, changed the fuel pump and fuel filter and boom, ta daaaa for me anyways
  8. #18
    as pete says, stick a fuel pressure gauge on it and run it into the car and see wat kinda pressure you have when it starts acting up
  9. #19
    Mar 2011
    carlow
    try your fuel filter
    i had a similar prob like this before and it turned out to be my air filter wasn"t restricting the air enough,,, silly but true changed the air filter then she ran fine... was after i changed nearly every part on the car...plugs afm coils fuel pump filters inter cooler pipes the lot... ended up getting a mad notion to change the air filter for some reason then it worked///
    check all your plugs are tight if one were to come loose it would spark all over the place causing detonation... hopefully you find it
  10. #20
    Dublin
    What boost you running there. Could be hitting fuel cut?? Did you get it mapped?
