Well I know that with my current alignment setup I run alot of toe out on the front for the sole purpose of causing some understeer through transition, to make it smoother effectively. MX5s are shorter wheelbase than even an 86 for example. The thinking is then that maybe the R888s grip combined with the lightweight nature of the car are maybe cancelling this effect out? The alignment setup I got is from Celsea DeNofa basically in the US who used to drift miatas (won the XDC over there in a E36 last year). However his settings were seriously extreme in the amount of toe out on front and toe in at the rear, so I effectively halved all his values.
