Results 1 to 10 of 14
Thread: sr20 oil leak
    Senior Member ste's Avatar
    north dublin
    Default sr20 oil leak
    well lads noticed and oil leak on the sil80 the day i got it only when engine is running so havin talked to a few people we thought it may have been the wrong oil filter fitted as the engine is a s14 engine....
    so changed oil this evening and still leaking...It seems to be comin from a sensor or solenoid (not sure wat it is) that sits just above oil filter going into the block...
    wat is this part and is it a big job sorry couldn get a pic as it was dark
    Chris Martina
    is it an oil filter relocator or standard position on engine ??
    He came up we chatted for a while nice fella to talk to all the same but he seemed very twitchy and i never trust a twitchy person....!
    north dublin
    ah standard position man the part that leaking threads into block i think and has electrical plug on it its only a small thing
    Chris Martina
    have you an oil pressure sensor/gauge ??
    Pro Driver
    Oil pressure switch dude, take it out bit of pipe tape on the threads and bobs your aunty,,,,,
    Incase you havnt noticed, this is driftireland! Not youraveragelookingcountryspeccivic,needsweelsandle sstackyshit.com!*
    north dublin
    there is a greddypressure guage but it not working think i need the sandwich plate to get it working
    north dublin
    Quote Originally Posted by Stonie View Post
    will oil piss out if i remove it brendan and do u mean ptfe tape
    Pro Driver
    It's the standard oil light switch,,,
    Quote Originally Posted by ste View Post
    do u mean ptfe tape
    yup he's on bout ptfe tape....like he said bolt it out bang some tape on an you'll be good to go
    north dublin
    Wink
    Cool will Do that today, will oil piss out when u remove it?
