Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    You'l need to change your clutch niall if u do this....!
  2. #12
    yea man wez jus said dat on message above,it s a pull rather dan push he said...il price dem n c wat crack is...
    sur maybe if i sold hks triple plate for rb20& rb25 i cud fund it towards new 1
  3. #13
    i have a gtr box for sale
  4. #14
    di Member GTSr32's Avatar
    Ted just get a rb25 box or put a new 3rd gear in ur own!! Alot of hassle really
  5. #15
    Quote Originally Posted by GTSr32 View Post
    a gtr box hassel?? wel it doesnt sound all dat bad bein honest wat do u know mr. driver(Dr.Skyline )????? all info a big help. man priced 3rd,400blips il get a box ta feic save all the fannyin around if i go that route.....rb26 seems b in round same price as rb25 but only ting den is how much is a clutch??? may have do prop again but dat b only little over 100. have enquire bout clutches
    did u have any luck with ur motor bro??
    thanks
  6. #16
    wel im not jumpin in2 anytin straight away until i konw wat clutch wil cost n other bits i will need ta do ta make dis happen....
    pm me a price tho and is it out of 32,33 or 34??
    cheers
  7. #17
    Pro Driver
    5 speed r32,r33 gt-r gearbox has the same strenght internals as a rb25 gts-t gearbox so ud be at feck all fitting
    If you get a r34 getrag box then it would be worth changing
  8. #18
    pm'd....The box i have came out off gts-4 which use the exact same box as the gtr but the gts-4 use a normal rb20det engine so its a push type clutch....i took the clutch off this engien and used it on my own rb20det in my cefiro so you could use your own clutch you have no need to be buying a new one...This ight save you alot off hassel
  9. #19
    Quote Originally Posted by carpo View Post
    thanks chris,
    fair play, i heard da 34gtr is da rolls royce of boxes allrite..i have rb25 in the r32 but blew 3rd out so prop n all is allready done....il have tink bout it over wkend n c wat im gonna go with..does any1 know if that is true wat 200sx is sayin, dat box of gts-4 is same as gtr or is it jus same size as rb20 box but 4wd.
    thanks to every 1 for advice and help!!!!! this site is sum job!!
