Results 1 to 10 of 22
    di Member pinny's Avatar
    Mar 2011
    Quote Originally Posted by thedaggsy View Post
    call me a butcher but it happened me as well and i leave the lens off the cluster now. it;s a full time tracker now
    my gauge stopped working so i brought a wire from the cam angle sensor and connected it to the back of the clock and it works spot on. use a multimeter if doing this to be on the safe side
    wher did you take the wire on the cas from ? wher did you connect it on the back of the clock ?
    My Phat Girl hunty_sideways's Avatar
    can ya borrow another set of clocks to see if they work,the womens 206 had the same problem the little motor that ran the needle just gave up
    Mar 2011
    i can get clocks from a s14a, plugs on the back surely the same ?
    would persume so but im sure somebody will know..
