nice build man
righto bit more done the last while engine and box are in now and sitting in place the engine seems to sit better in this than the r32 as theres loads more room to work on both sides of the engine but less room at the front
anyone guess the turbosteel wheeled rb25 turbo modified to fit a top mount apexi manifold wit internal gate welded closed so i can run an external wastegate
also for added reliablity i fitted a oil cooler and relocation kit to make oil changes easier
also refitted and made brakets for the electric fan oil cooler and intercooler all mounted high and well back behind the bumper bar to hopefully protect them a bit if the worst happens
also started to fit the front wings so i can start to lower it and get the ride height sorted and make brakets to hold the wing at the front
not much of an update but got the propshaft made for this and fitted during the week
also took it out of the shed where i was working and got it up to calicages racings yard where work will start in the next few days on building the cage and intercooler pipe work and basically getting it finished and ready for out
more pics when work starts
Looking go lad should be a good competive car....! Why u paint the inside and then put a cage in after......![]()
hopefully it,ll be competive some day but the way things r at the min it,ll just be used for pratice days
theres plates in the floor for a cage so im just gonna throw a bolt in cage into it and build a proper shell when moneys a bit more flush
plus if i stack this shell its just a matter of bolting everything out and into another 180
so got a few more small bits done at this again got nelly out with the welder and we made up the intercooler pipe for the turbo side really happy with the way it turned out it fits like a glove and only 2 samcos needed so hopefully will lessen the chance of boost leaks or pipes blowing off
to clean them up and freshen up the engine bay i sprayed them blue just need to get lacquer tomorrow and finish them off
also to freshen the bay i pulled off the rocker covers and cleaned them down and sprayed them up
will update more over the next few days as we get more jobs done
What is the story with the clutch in the background of pic 5???in the same pic is that your toolbox/trolley on the right lol
Im liking this...good job man!
My S14 Dori Project: http://www.driftireland.com/forum/sh...ad.php?t=10638
