Results 1 to 7 of 7
    Jan 2011
    Default nismo 740's or 555?
    just wanted to see what people thought would be better for me to run on my set up....
    Block was bored hones and skimmed
    Crank polished
    Eagle rods
    Wiseco 86.5mm pistons
    Cometic 1.6mm gasket
    Head mild porting
    brain crower valves,springs...
    z32
    apexi power fc ecu
    front mount
    255 walbro pump
    thanks thats it might be a few other little bits....
    Any help would be great?
    Quote Originally Posted by mrsheen04 View Post
    Crank polished
    Eagle rods
    Head mild porting
    z32
    apexi power fc ecu
    front mount
    255 walbro pump
    Need to know what tubby your running.....
    Jan 2011
    Sorry knew there was something I left out I'm gonna be running a 2871r
    I would imagine 740's would be ok with that kind of spec and turbo.
    I stand to be corrected though.
    di Member bart's Avatar
    laois
    i'd go with the 550's
    would you not just ask your mapper?????????
    Member
    waterford/kilkenny
    555 would be just fine,,,you can go with 740's but its better when choosing an injector size to match it as close to ur spec as possible(what hp power ect),as its more controllable and also performs better.so 555 would be just fine
    You'd be making nice figures with a bigger turbo and 740's
    with the internal mods you have
    Could be more trouble than it's worth though
