This is my project combining 2 things I love, ae86 and VVL....
My Ae86 started life with me shortly after my younger brother died, he was more mad about ae86's then I was and had always wanted a Jap kitted cam!
He had already started saving for one at the age of 15.
Didnt take me long to decide to buy a mad looking cam in his memory.
When I first got my ae86 it was already fairly specced out with a nice 20v engine from an ae111.
One day talking with a mate I decided I wanted more power so started discussing sr20det but this had been done and done
so I wanted something different.
An sr20det in an ae86 although fun I really love a high revving NA car!
So decided to stay NA with some of Nissans finest VVL!
Will be going with a high revving NA build with a target of 250+ hp which is a very realistic goal with the spec!
Some will be saying why didnt I just drop a F20C vtec but to me that would be a sin!! Not too mention its been dones plenty already.
Anyway bare with me as this will be a long build!
Heres a bit about VVL........
NEO VVL:
Nissan Ecology Oriented Variable Valve Lift and Timing (commonly known as VVL) is an automobile
variable valve timing technology developed by Nissan.
It was Nissans answer to VTEC!
VVL varies the timing, duration, and lift of valves by using hydraulic pressure switch between two different
sets of camshaft lobes. It functions similarly to Honda's VTEC system.
Basically what i'll be doing is bolting a vvl head (sr16ve) from a VZR to a rwd sr20 block using a 6 speed S15 box! Simples...
So anyway here is a few pics before I started.
Here is the expected spec list with most of it already sitting in the spare room!
I have been building up the parts for a long time now!
Probably left loads out but like any other project the list will change!!
ENGINE:
SR20 RWD block resleeved to 90mm
Darton sleeves (can go 92mm if you want!)
90mm 12.5:1 CR CP pistons
sr20det 8cw crank
BC lightweight rods
ACL race bearings set
Cometic 90mm metal headgasket
Custom made Drysump kit
Sr16VE VVL head
Full port & polish
BC titanium springs & retainers
Supertech oversize valves +1mm intake, +2mm exhaust
Cams (unsure yet, maybe franklin stage4's)
50mm M3 CSL itb's
Custom intake manifold to match itb's
Custom 4-1 header
Custom 3" exhaust
Mazworx VVL relocator
Mezeire electric water pump
Alloy radiator
Twin 10" electric fans (have to order yet)
Omex engine management
DRIVETRAIN:
S15 6 speed gearbox
orc super single clutch
Lightweight flywheel
Custom shaft
4.778 Final Drive
Competition Spec 2-Way LSD (unsure of Brand)
Weir solid pinion spacer
EXTERIOR:
Carbon JBlood doors
Carbon Origin vented bonnet
Carbon Boot with moulded TRD spoiler in carbon
Carbon eyebrows
Carbon door sills
Carbon wiper panel
Carbon rad shoud
Cashiew Mirrors (Dipped in carbon)
Mercury R Front Bumper
Mercury R Side Skirts
Mercury R Rear Diffuser
Origin 20mm Wider Vented Front Arches
Origin 35mm Wider Rear Arches
Redlines (might get them converted to LED yet!)
Polycarbonate windows (have to order yet)
INTERIOR:
Full Cage by Rocco performance
Fully stripped interior
FRP flocked dash with carbon insert (Galway carbon)
Carbon door cards (Galway carbon)
Carbon heater console (will house switches and no heating!)
Defi 60mm BF gauges
-Oil pressure
-Oil temp
-Water temp
-Fuel pressure
Defi 80mm BF 11k rpm Tach
SARD time attach meter
2*Bride FRP Zeta III full bucket
2* Takata 6 point harnesses
Sparco Steering Wheel
SUSPENSION AND HANDLING:
Seam Welded
Cusco Coilovers and Adjustable Topmounts with Uprated Springs (Front)
TRD Blue 8-Way Adjustable Shocks with Uprated Springs (Rear)
Adjustable Panhard Rod
All Suspension Fully Rosejointed
Anti-Tramp Bars
Extra Lock Kit
WHEELS AND BRAKES:
Front: Wilwood 4 piston Forged Dynalites (not sure on pad yet)
Rear: Black Diamond Grooved and Cross Drilled Brake Discs
Project Mu D1 Spec Rear Pads
Goodridge Braided Brake Lines
GRP4 Perfomance Hydraulic Handbrake
15" 9.5J -19 Watanabe
Let the stripping begin....
Engine box and loom got shipped to new owner in UK!
At this stage I thought I would just be doing an engine swap but I kept stripping...
Also while I was at it stripped the vvl engine from a donar...
From here it went to Rocco performance for new engine mounts and shaft.
While there I seen some of his work on cages and decided to go with a Rocco cage!
Also decided while I was going this far i'd make sure I didnt have to do any rust repairs in a years time
so decided on a full strip with a sodablast to show any rust hiding...
sodablast showed up a few issues with sills but overall in very good cond.
Here's some pics of the car as it sits after blast.
Waiting on the cage and then its going off for some fab work on the sills.
In the mean time i'll show some pics of the goodies....
Carbon...
ITB's
Valve cover....
UPDATE 18/1/11
Rocco finished car leaving me with new cage/mounts and small bit of tunnel work.
While it was there I had it soda blasted to see what was lying beneath all the paint!
Found a few suprises but nothing too serious but decided too have them all sorted now so a long trip from Mayo to Rocco to Goldie and back to Mayo...
Goldie is a legend to deal with, Done some work on the sills/arches so hopefully no rust again!
A rusty pic...
Got him to weld up all the extra holes on engine bay too
Few more snaps...
So for now its back in the shed waiting on paint...
Pair of Bride Zeta III frp arrived today with fg rails thanks to Carpo! Snug is the word.... Time for weight watchers!!
Picked up 2 6 point Takata's too so should look like this when finished......:love::love:
