Results 1 to 9 of 9
    Default rb25 turbo on rb20?
    scraic lads. My turbo has a bit more play than id lik so im thinkin of changing it to an rb25 turbo. I dont hav the money so dont bother naming them. Would an rb25 turbo be any more laggy than a rb20 one? Or would it be a minimal difference an would i be better with another rb20 turbo?
    Thanx
    Rb25 are a good cheap upgrade for an rb20...turbo's are good and spooly,no difference at all really.....There able to hold about 14psi off pressure aswell,a little bit better the the standerd rb unit!
    they should fit straight on doogle...think alan is runnin one on his rb20 iirc
    di Member nicky h's Avatar
    dungarvan co waterford
    there the job lad theres one on aimees 32 now ! makes good power
    di Member mick-skyline's Avatar
    Yes they are gaslight upgrade for the rb20, if you get one you need the intake elbow too, the 3 bolt on the front as there's a slight difference in the rb20 and rb25 size. Everything else bolts up
    Quote Originally Posted by mick-skyline View Post
    Ya mean outlet elbow
    Depending on price I'd consider one but the gains would be small
    I'm pretty sure a r34 turbo will bolt on as well,arnt the later r34's ball bearing? Open to correction
    Quote Originally Posted by Davie View Post
    no i mean inlet elbow , the outlet is the one before the downpipe isnt it......
    bottom left in this pic is where it bolts to.... on the INtake housing
    its not low enough!
    dont think so ted but i think they do have metal compressor blades, ive an rb25 nylon bladed jobby on mine, i got it for nothing so put it on, its good ! did give me abit more power, im using the rb20 actuator, running about .7 bar
    nice one for the input lads. Did you hav to change the inlet pipe alan?
