give more info lad, what type of paint was used, was it painted over the cold spell of the winter? if it was painted over the cold spell then the paint went dull from the artic temps, never paint in cold weather unless you have an oven to do so.
right, theres a very good chance it didn't keep its shine cause of the cold, with 2k you can flattin and polish(power polish)
use1500-2000 wet and dry to flattin it and polish with G3 and it might come back up to decent sheen, thats a big might!
the other thing when using 2k is on the final coat your meant to add extra thinners to bring out a good shine.
hope this helps ya lad
Its possible the laquer was put on too dry..too far away from the panel with the gun, moving too fast with the gun etc. If this is the case the only way your goin to fix it is repaint it, no amount of flattening and buffing will do.
he said it was painted in 2k lad no lacquer involved.
if it won't shine scuff it and an other finish coat should shine it up nicely.
if it didn't shine after more paint the paint is not good and you'd need fresh paint.
there's one other thing , once i came across some 2k in orange and yellow and the stuff wouldn't shine at all no matter what (something not right in the paint) a clear coat of lacquer will sort it (was a full respray) in your case it might not match the rest of the car.
It will polish up wet sand it 1500 then go over it with 2000 you ll need a buffer set it around 2500 that g3 stuff isn't great IMO better with 3m compound used a hard pad and a hard compound then go over it with a soft pad and a finish compound and you ll get a really nice shine .
The cold has nothing to do with the lack of a shine by the way it was probably just put on to dry
at -10 to -16 with out right heat it would fade, i'v been painting 12 year lad. by adding the thinners to last coat it reduces that dry coat effect and gives a nice wet looking shine.
every paint will f up if used below a certain temp. dampness infects the top layer resulting in dull finish.
Cheers lads for that, il get them sorted this week, an when its back on the road il get a few pics up![]()
