Abso-fucking-lutely amazing work. Might we see this in Ireland in 2011?
serious machine man.. best of luck with it!!
really nice work lads,some serious engineering there
Serious build AGAIN!!...... Id still have second thoughts on keeping the front cross member because if you have a sideways front corner tip it'l push everything off to one side!!......but then again if you are unfortunate enough to hit head on, your fucked tooanyway!!!
Signature removed
looking well dude
Cheers guys!
Its that time again!
Not done too much as im waiting on parts which i couldnt afford :wack: now iv sold my daily s14a i can crack on again
Oil pipes, one way valve and T for Accusump.
Made a few fittings to get welded in to the boost pipes, one for the air temp sensor and the other for boost control (one for each wastegate and one for the controller)
Fuel tank got a clean and paint
Some under floor bracing and filler neck fitted
HSD's
Neck protector
Thinking of swapping out the stock spring pan arm for a modified s14 toe arm. Its about 3inch too short ATM.
Seriously cool, great work, keep the updates coming fast![]()
just noticed there is a bit missing!!
Pipercross came and mesured up for my new filter
And i got the fuel tank in, along with a few other cleaned up and painted bits
Now iv got a bit of cash from the daily tomorow il be ordering all sorts of bits so i can move on!
some build ,cant wait to see the finnished product .
